How to Fix Stuck Yamaha PSR-6 Keyboard Keys
  1. How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 1, image 1 of 3 How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 1, image 2 of 3 How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 1, image 3 of 3
    • Turn around the keyboard with the keys facing down.
    • Remove the 15 10 mm screws using a Phillips #1 screwdriver.
    • Remove the five 12 mm screws using a Phillips #1 screwdriver.
    • Remove the extra two 10 mm screws in the bottom using a Phillips #1 screwdriver.
    Ask FixBot
  2. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 2, image 1 of 1
    • Pull the tab and remove the battery cover.
    Ask FixBot
  3. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 3, image 1 of 1
    • Take the back plate of the piano with both hands and remove it.
    Ask FixBot
  4. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 4, image 1 of 2 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 4, image 2 of 2
    • Turn around the piano with the tiles facing up.
    • Remove the speaker's cover on the left side of the keyboard.
    • Remove the plastic cover on the right side of the keyboard.
    Ask FixBot
  5. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 5, image 1 of 2 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 5, image 2 of 2
    • Flip the keyboard with the keys facing down.
    • Remove the single 12 mm screw using a Phillips #1 screwdriver.
    Ask FixBot
  6. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 6, image 1 of 1
    • Lift the front plate of the keyboard and rotate it 180°.
    • While doing this, grab the speaker with the other hand so it doesn't fall and hit the table.
    Ask FixBot
  7. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 7, image 1 of 2 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 7, image 2 of 2
    • Remove all the 10 mm screws on the top of the keys using a Phillips #1 screwdriver.
    Ask FixBot
  8. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 8, image 1 of 1
    • Use a spudger to separate the teeth to the plates that hold the keys together.
    • Do this gently as the plate may be fragile.
    Ask FixBot
  9. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: step 9, image 1 of 1
    • Pull the black plate that holds the keys together horizontally away from the keys.
    • With the top of the keys exposed, use a damp cloth or wipes to clean the space between the tiles.
    Ask FixBot
5 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 69
All Time: 3,003
