Up to 20% off select tools
How to Fix Stiff Slime
Views: 1.8K
View statistics:
Past 24 Hours:
15
Past 7 Days:
93
Past 30 Days:
461
All Time:
1,829
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Slime can often be a source of relaxation and entertainment. However, if you've had slime for any amount of time, you're likely aware of how it shrinks and stiffens over time due to constant use. Thankfully, fixing this issue is a quick and easy process!
If you want to keep your slime active for longer, follow this guide to give your slime its stretch and gooey texture back! Make sure that you have a clean container to put your slime into, as well as space that is clear and uncluttered.
    1. How to Fix Stiff Slime, How to Fix Stiff Slime: step 1, image 1 of 2 How to Fix Stiff Slime, How to Fix Stiff Slime: step 1, image 2 of 2
      • Break the stiff slime into small chunks and place into the container.
      Ask FixBot
    2. How to Fix Stiff Slime: step 2, image 1 of 2 How to Fix Stiff Slime: step 2, image 2 of 2
      • Add 1 pump of lotion into the container.
      Ask FixBot
    3. How to Fix Stiff Slime: step 3, image 1 of 3 How to Fix Stiff Slime: step 3, image 2 of 3 How to Fix Stiff Slime: step 3, image 3 of 3
      • Knead the slime.
      Ask FixBot
    4. How to Fix Stiff Slime: step 4, image 1 of 2 How to Fix Stiff Slime: step 4, image 2 of 2
      • If the slime is still stiff, add warm water with a 1:10 ratio and knead for 3-5 minutes.
      Ask FixBot
    5. How to Fix Stiff Slime: step 5, image 1 of 1
      • If the slime is still stiff, add baby oil with a 1:20 ratio.
      Ask FixBot
    6. How to Fix Stiff Slime: step 6, image 1 of 2 How to Fix Stiff Slime: step 6, image 2 of 2
      • Continue to knead until the lotion, water, and baby oil dissolve into the slime.
      Ask FixBot
    7. How to Fix Stiff Slime: step 7, image 1 of 3 How to Fix Stiff Slime: step 7, image 2 of 3 How to Fix Stiff Slime: step 7, image 3 of 3
      • Repeat Steps 2-6 until the slime is pliable.
      Ask FixBot
Finish Line
Author
with
dellpk
163 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 93
Past 30 Days: 461
All Time: 1,829
