Up to 20% off select tools
How to Fix Semi-Rimless Glasses
Views: 72K
View statistics:
Past 24 Hours:
13
Past 7 Days:
116
Past 30 Days:
464
All Time:
71,547
Comments: 12
3 comments on steps, 9 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to repair semi-rimless glasses with a broken or loose retaining thread or lenses that have come out of the spectacles. This is a quick, simple repair. It can be done at home easily with tools like tweezers, fishing thread (as per the glass hole size), nail cutters, and scissors.
      • Inspect frame to make certain the Monofilament Lens Retainer is broken. If the wire is not broken, your lens has fallen out and can easily be re-inserted. If the wire is broken refer to the following steps.
      Ask FixBot
    1. How to Fix Semi-Rimless Glasses: step 2, image 1 of 2 How to Fix Semi-Rimless Glasses: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the old wire/string from the spectacles using the tweezers as shown in the pictures to the right.
      Ask FixBot
    2. How to Fix Semi-Rimless Glasses: step 3, image 1 of 3 How to Fix Semi-Rimless Glasses: step 3, image 2 of 3 How to Fix Semi-Rimless Glasses: step 3, image 3 of 3
      • Cut the new fishing wire between 7 and 9 inches.
      Ask FixBot
    3. How to Fix Semi-Rimless Glasses: step 4, image 1 of 2 How to Fix Semi-Rimless Glasses: step 4, image 2 of 2
      • Hold the glasses in the position shown in the image. There will be a hole near the nose pad, shown by the arrow in the second photo, you will use this to insert the new wire.
      Ask FixBot
    4. How to Fix Semi-Rimless Glasses: step 5, image 1 of 3 How to Fix Semi-Rimless Glasses: step 5, image 2 of 3 How to Fix Semi-Rimless Glasses: step 5, image 3 of 3
      • Insert one end of the wire into the hole near the pad arm and insert the other end to the opposite side of the glasses, then tie the knot as shown in the images.
      Ask FixBot
    5. How to Fix Semi-Rimless Glasses: step 6, image 1 of 3 How to Fix Semi-Rimless Glasses: step 6, image 2 of 3 How to Fix Semi-Rimless Glasses: step 6, image 3 of 3
      • You will see a thin groove along the edge of the glasses. Carefully fix the wire around the groove as shown in the pictures.
      Ask FixBot
    6. How to Fix Semi-Rimless Glasses: step 7, image 1 of 3 How to Fix Semi-Rimless Glasses: step 7, image 2 of 3 How to Fix Semi-Rimless Glasses: step 7, image 3 of 3
      • After placing the wire around the glasses, stretch the wire, tie it, and make a knot by holding the glasses tightly.
      • Do not tie a knot at the end of wire, but at the location where the wire is holding the glasses tightly.
      Ask FixBot
    7. How to Fix Semi-Rimless Glasses: step 8, image 1 of 3 How to Fix Semi-Rimless Glasses: step 8, image 2 of 3 How to Fix Semi-Rimless Glasses: step 8, image 3 of 3
      • Now, cut the extra wire from both sides of the glasses using the nail cutter.
      • Use of scissors might make it difficult to cut extra wire. So, we suggest you use nail cutter to cut extra wire.
      • Pay extra attention while cutting a wire, as you might cut more than needed and loosen it, which could lead you to start over.
      Ask FixBot
    8. How to Fix Semi-Rimless Glasses: step 9, image 1 of 3 How to Fix Semi-Rimless Glasses: step 9, image 2 of 3 How to Fix Semi-Rimless Glasses: step 9, image 3 of 3
      • In the end, check if your glasses are tight enough to wear. If the glasses are tight, they are ready to wear.
      Ask FixBot
10 other people completed this guide.
Author
with
Sabina Paneru
339 Reputation
1 Guide authored
9 Guide Comments
I fixed mine with floss…
Ryo Saeba - Reply Share
I was just gonna comment this! Used floss and it worked great. Thank you for this article though, it was very helpful!
jcmills4 - Reply Share
Using floss is a genius idea… combined with this article.
I don’t have the fishing line available (need to order it but that means days of wait), so I need a quick way to fix it (at least for short term).
Floss won’t work for the more authentic repair way (tightening without tying a knot), but it works well here as I have floss at home!
(yes a long term better fix is what HIK mentioned, but it requires a good measure of the thickness of the hole / string to ensure a tight fit)
Wei Zhang - Reply Share
I dont agree with above method, it will end in a very visible knot on both side of glass. The professional way is to pass the wire from one hole and again back in from another hole place the glass and stretch the wire on both sides, it will make it hold the glass tightly, no need for a knot. Just look at any half frame carefully and you will understand.
HIK - Reply Share
I was not aware frames came like this, right lens wire snapped, I see how to repair, but my hands are not steady, would a eye glass store help?
whitehouse4330 - Reply Share
Past 24 Hours: 13
Past 7 Days: 116
Past 30 Days: 464
All Time: 71,547
