How to Fix RV Toilet Water Pressure
  1. How to Fix RV Toilet Water Pressure, How to Fix RV Toilet Water Pressure: step 1, image 1 of 3 How to Fix RV Toilet Water Pressure, How to Fix RV Toilet Water Pressure: step 1, image 2 of 3 How to Fix RV Toilet Water Pressure, How to Fix RV Toilet Water Pressure: step 1, image 3 of 3
    • Wrap the thread tape around the 1/2" nipple, 2-3 times in a counter-clockwise motion.
    • Make sure the nipple is fully covered, but the ends are open.
    Ask FixBot
  2. How to Fix RV Toilet Water Pressure: step 2, image 1 of 2 How to Fix RV Toilet Water Pressure: step 2, image 2 of 2
    • Screw the nipple onto the regulator, making sure the arrow (marked by the red circle) is pointing away from the nipple.
    • Be sure to screw the nipple in as tight as you can with just your fingers.
    Ask FixBot
  3. How to Fix RV Toilet Water Pressure: step 3, image 1 of 3 How to Fix RV Toilet Water Pressure: step 3, image 2 of 3 How to Fix RV Toilet Water Pressure: step 3, image 3 of 3
    • Wrap the thread tape around the pressure gauge 2-3 times, in a counter-clockwise motion.
    • Make sure the thread is fully covered, but the end is open.
    • Do not thread the gauge in yet. Instead, note the angled slot where it will be installed in step 10.
    Ask FixBot
  4. How to Fix RV Toilet Water Pressure: step 4, image 1 of 3 How to Fix RV Toilet Water Pressure: step 4, image 2 of 3 How to Fix RV Toilet Water Pressure: step 4, image 3 of 3
    • Turn the external water source (outside faucet) off.
    Ask FixBot
  5. How to Fix RV Toilet Water Pressure: step 5, image 1 of 1
    • Turn on the sink faucet and let it run until no more water comes out to drain the lines.
    • Flush the toilet to drain any remaining water in the lines.
    Ask FixBot
  6. How to Fix RV Toilet Water Pressure: step 6, image 1 of 2 How to Fix RV Toilet Water Pressure: step 6, image 2 of 2
    • Unscrew the water inlet line from the toilet.
    • Lay a towel down as some water may drip out.
    Ask FixBot
  7. How to Fix RV Toilet Water Pressure: step 7, image 1 of 2 How to Fix RV Toilet Water Pressure: step 7, image 2 of 2
    • Screw the regulator onto the back of the toilet where the water line was screwed in.
    • The arrow should point to the back of the toilet.
    Ask FixBot
  8. How to Fix RV Toilet Water Pressure: step 8, image 1 of 3 How to Fix RV Toilet Water Pressure: step 8, image 2 of 3 How to Fix RV Toilet Water Pressure: step 8, image 3 of 3
    • Screw the water inlet line onto the nipple attached to the regulator.
    • This may be difficult, but be sure NOT to cross-thread.
    • Make sure to screw it in tight (finger tight), but do not over tighten.
    Ask FixBot
  9. How to Fix RV Toilet Water Pressure: step 9, image 1 of 2 How to Fix RV Toilet Water Pressure: step 9, image 2 of 2
    • Screw the pressure gauge onto the regulator.
    • Tighten it all the way down as far as you can with finger strength.
    Ask FixBot
  10. How to Fix RV Toilet Water Pressure: step 10, image 1 of 3 How to Fix RV Toilet Water Pressure: step 10, image 2 of 3 How to Fix RV Toilet Water Pressure: step 10, image 3 of 3
    • Turn the water back on.
    Ask FixBot
  11. How to Fix RV Toilet Water Pressure: step 11, image 1 of 1
    • Check to make sure nothing is leaking.
    • If one of the fittings is leaking you may need to remove it and put more tape on the nipple.
    Ask FixBot
  12. How to Fix RV Toilet Water Pressure: step 12, image 1 of 3 How to Fix RV Toilet Water Pressure: step 12, image 2 of 3 How to Fix RV Toilet Water Pressure: step 12, image 3 of 3
    • Remove the cap from the top of the regulator.
    Ask FixBot
  13. How to Fix RV Toilet Water Pressure: step 13, image 1 of 3 How to Fix RV Toilet Water Pressure: step 13, image 2 of 3 How to Fix RV Toilet Water Pressure: step 13, image 3 of 3
    • Take the Allen Key and insert it in the top of the regulator.
    • Twist the Allen Key while running water into the toilet until the desired water pressure is achieved.
    Ask FixBot
  14. How to Fix RV Toilet Water Pressure: step 14, image 1 of 3 How to Fix RV Toilet Water Pressure: step 14, image 2 of 3 How to Fix RV Toilet Water Pressure: step 14, image 3 of 3
    • Screw the cap back on to the regulator.
    • Enjoy the new water pressure.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 83
All Time: 666
