How to Fix Plastic Chair Cracks
    1. How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: step 1, image 1 of 2 How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: step 1, image 2 of 2
      • Lay the broken chair such that the crack is parallel to the floor.
      Ask FixBot
    2. How to Fix Plastic Chair Cracks: step 2, image 1 of 2 How to Fix Plastic Chair Cracks: step 2, image 2 of 2
      • Wear gloves to minimize chemical contact on skin.
      • Dampen a rag with isopropyl alcohol.
      Ask FixBot
    3. How to Fix Plastic Chair Cracks: step 3, image 1 of 2 How to Fix Plastic Chair Cracks: step 3, image 2 of 2
      • Clean the surface of the crack with the dampened rag to remove all dust and debris.
      • Repeat on all sides of the crack (edges and backside).
      Ask FixBot
    4. How to Fix Plastic Chair Cracks: step 4, image 1 of 3 How to Fix Plastic Chair Cracks: step 4, image 2 of 3 How to Fix Plastic Chair Cracks: step 4, image 3 of 3
      • Apply glue between the crack.
      • Then apply glue across the surface of the crack.
      Ask FixBot
    5. How to Fix Plastic Chair Cracks: step 5, image 1 of 1
      • Hold the two glued pieces together for 30 seconds to allow the glue to bind to the chair.
      • Do not let the glue dry completely. The wet glue will need to bind with baking soda in the next step.
      Ask FixBot
    6. How to Fix Plastic Chair Cracks: step 6, image 1 of 3 How to Fix Plastic Chair Cracks: step 6, image 2 of 3 How to Fix Plastic Chair Cracks: step 6, image 3 of 3
      • Pour baking soda over the crack until the glue is completely covered under a layer of baking soda.
      Ask FixBot
    7. How to Fix Plastic Chair Cracks: step 7, image 1 of 2 How to Fix Plastic Chair Cracks: step 7, image 2 of 2
      • Use your finger to distribute the baking soda in order to cover all parts of the crack.
      Ask FixBot
    8. How to Fix Plastic Chair Cracks: step 8, image 1 of 3 How to Fix Plastic Chair Cracks: step 8, image 2 of 3 How to Fix Plastic Chair Cracks: step 8, image 3 of 3
      • Allow the baking soda to seal onto the super glue over the crack and wait for the mixture to dry.
      • After ten minutes, brush away some of the un-glued baking soda to check if the glue is solid.
      Ask FixBot
    9. How to Fix Plastic Chair Cracks: step 9, image 1 of 2 How to Fix Plastic Chair Cracks: step 9, image 2 of 2
      • Flip the chair over.
      • Repeat the procedure on the backside of the crack starting from step 4 and ending with step 8.
      • Avoid reapplying glue in between crack, since it has already been sealed.
      Ask FixBot
    10. How to Fix Plastic Chair Cracks: step 10, image 1 of 2 How to Fix Plastic Chair Cracks: step 10, image 2 of 2
      • Remove excess baking soda from both the front and back side of the crack.
      • Use water or isopropyl alcohol to remove fine grains around the repair site.
      Ask FixBot
    11. How to Fix Plastic Chair Cracks: step 11, image 1 of 1
      • Sand off any excess layers of glue on both the front and backside of the chair using coarse sandpaper.
      • This step is optional and simply helps to return the chair to its original look.
      • It may take a while to rid the chair of all texture.
      Ask FixBot
    12. How to Fix Plastic Chair Cracks: step 12, image 1 of 1
      • The crack has been repaired!
      Ask FixBot
Finish Line
20 other people completed this guide.
Sumeet Dhillon
565 Reputation
1 Guide authored
UC Davis, Team S2-G7, Andersen Winter 2020 Member of UC Davis, Team S2-G7, Andersen Winter 2020
UCD-ANDERSEN-W20S2G7
3 Members
12 Guides authored
4 Guide Comments
Do you push the baking soda down into the glue (or into the crack), or just spread evenly on the surface?
Dr John Christensen - Reply Share
What glue did you use?
Raffaele Bianchi - Reply Share
Lem apa yang digunakan (nama lem)
Iwan Toro - Reply Share
There is also duct tape.
Theo Grefalda - Reply Share
Past 24 Hours: 31
Past 7 Days: 184
Past 30 Days: 734
All Time: 64,490
