How to Fix Oculus 2 Quest Controller Drift Without Disassembly
  1. How to Fix Oculus 2 Quest Controller Drift Without Disassembly, How to Fix Oculus 2 Quest Controller Drift Without Disassembly: step 1, image 1 of 1
    • Remove the battery cover from the controller.
    • Remove the battery.
    Ask FixBot
  2. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: step 2, image 1 of 2 How to Fix Oculus 2 Quest Controller Drift Without Disassembly: step 2, image 2 of 2
    • Flip the straw up on the WD-40 for a pinpoint stream.
    • Make sure to use WD-40 specialist contact cleaner as opposed to traditional WD-40 which may damage your controller.
    Ask FixBot
  3. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: step 3, image 1 of 3 How to Fix Oculus 2 Quest Controller Drift Without Disassembly: step 3, image 2 of 3 How to Fix Oculus 2 Quest Controller Drift Without Disassembly: step 3, image 3 of 3
    • Shake the can well for 20 to 30 seconds before each spray.
    Ask FixBot
  4. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: step 4, image 1 of 1
    • Hold the joystick down in the opposite direction of the drift.
    Ask FixBot
  5. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: step 5, image 1 of 1
    • Spray a small amount of the product into the joystick
    • It's important to use WD-40 specialist contact cleaner instead of the regular WD-40. It will break the controller if you use the wrong can.
    Ask FixBot
  6. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: step 6, image 1 of 3 How to Fix Oculus 2 Quest Controller Drift Without Disassembly: step 6, image 2 of 3 How to Fix Oculus 2 Quest Controller Drift Without Disassembly: step 6, image 3 of 3
    • Wiggle the joystick around in circles to spread the residue.
    • Click the joystick down a couple of times.
    Ask FixBot
  7. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: step 7, image 1 of 1
    • Wait for the the residue to dry for 3 minutes.
    • Replace the battery.
    Ask FixBot
Finish Line
13 other people completed this guide.
Adrian Sanchez
458 Reputation
1 Guide authored
8 Guide Comments
In the article you warn the user:
"It's important to use WD-40 specialist contact cleaner instead of the regular WD-40. It will break the controller if you use the wrong can."
Are you referring to the "WD-40 Specialist ELECTRICAL Contact Cleaner" or just the "WD-40 Specialist Contact Cleaner?"
They're apparently two different products, with the former coming in a black/dark gray can (at twice the price) and the latter coming in the dark blue can that WD-40 has traditionally come in, and I don't want to pick up the wrong product for this.
Thanks for your time!
WafflesASAP - Reply Share
I feel that it being an electronic that it will use the electronic contact cleaner.
Francisco 1234 Cruz YT - Reply Share
https://www.wd40.com/products/contact-cl... - The page indicates that they changed the appearance of the can, not the formulation. The two products you describe are the same one.
jon42 - Reply Share
B and Y buttons no longer work after I used this method and fixed the stick drift.
Morgen Hoshi - Reply Share
Did not really work, didn’t even break the controller either, I should probably try again or something, also when I used the normal WD-40 it did not break anything but I am still suggesting to use the WD-40 specialist ELECTRICAL contact cleaner, have a nice day mate
ICameHereForWisdom - Reply Share
Past 24 Hours: 7
Past 7 Days: 60
Past 30 Days: 345
All Time: 31,977
