How to Fix Nintendo Switch Joy Con Stick Drift
    1. How to Fix Nintendo Switch Joy Con Stick Drift, How to Fix Nintendo Switch Joy Con Stick Drift: step 1, image 1 of 3 How to Fix Nintendo Switch Joy Con Stick Drift, How to Fix Nintendo Switch Joy Con Stick Drift: step 1, image 2 of 3 How to Fix Nintendo Switch Joy Con Stick Drift, How to Fix Nintendo Switch Joy Con Stick Drift: step 1, image 3 of 3
      • Flip the device over.
      • On the Joy-Con that is experiencing stick drift, hold down the release button and slide the Joy-Con off.
      Ask FixBot
    2. How to Fix Nintendo Switch Joy Con Stick Drift: step 2, image 1 of 2 How to Fix Nintendo Switch Joy Con Stick Drift: step 2, image 2 of 2
      • Pour a small amount of rubbing alcohol onto the lid and dip your cotton swab into it.
      Ask FixBot
    3. How to Fix Nintendo Switch Joy Con Stick Drift: step 3, image 1 of 3 How to Fix Nintendo Switch Joy Con Stick Drift: step 3, image 2 of 3 How to Fix Nintendo Switch Joy Con Stick Drift: step 3, image 3 of 3
      • While slowly rotating the joint of the stick, use the cotton swab to sweep beneath the rubber that holds the joy stick cover to remove any debris.
      Ask FixBot
    4. How to Fix Nintendo Switch Joy Con Stick Drift: step 4, image 1 of 3 How to Fix Nintendo Switch Joy Con Stick Drift: step 4, image 2 of 3 How to Fix Nintendo Switch Joy Con Stick Drift: step 4, image 3 of 3
      • Swirl the joystick around 2 or 3 times.
      Ask FixBot
    5. How to Fix Nintendo Switch Joy Con Stick Drift: step 5, image 1 of 1
      • Allow the Joy-Con to sit for at least 30 seconds.
      Ask FixBot
    6. How to Fix Nintendo Switch Joy Con Stick Drift: step 6, image 1 of 3 How to Fix Nintendo Switch Joy Con Stick Drift: step 6, image 2 of 3 How to Fix Nintendo Switch Joy Con Stick Drift: step 6, image 3 of 3
      • Slide the Joy-Con back onto the side of the Switch's body.
      Ask FixBot
    7. How to Fix Nintendo Switch Joy Con Stick Drift: step 7, image 1 of 3 How to Fix Nintendo Switch Joy Con Stick Drift: step 7, image 2 of 3 How to Fix Nintendo Switch Joy Con Stick Drift: step 7, image 3 of 3
      • Turn on the Switch and go to the home screen.
      • Click on "System Settings."
      • Click on "Controllers and Sensors."
      • Click on "Calibrate Control Sticks."
      Ask FixBot
    8. How to Fix Nintendo Switch Joy Con Stick Drift: step 8, image 1 of 3 How to Fix Nintendo Switch Joy Con Stick Drift: step 8, image 2 of 3 How to Fix Nintendo Switch Joy Con Stick Drift: step 8, image 3 of 3
      • Recalibrate the joystick by following the instructions on the screen.
      Ask FixBot
With this fix, your Nintendo Switch Joy-Cons should not experience any more stick drift.
12 other people completed this guide.
Gabriella Su
391 Reputation
1 Guide authored
UC Davis, Team 1-8, Morris Fall 2024 Member of UC Davis, Team 1-8, Morris Fall 2024
UCD-MORRIS-F24S1G8
3 Members
12 Guides authored
2 Guide Comments
This isn't the symptom of stick drift, at all. If there's debris causing movement, that would be instantly resolved if debris was removed. You wouldn't need to Calibrate it.
Zakariya Ali - Reply Share
great it worked thanks!
MNO .k - Reply Share
Past 24 Hours: 20
Past 7 Days: 143
Past 30 Days: 621
All Time: 20,511
