Up to 20% off select tools
How to Fix Left Joy-Con Sync Issues
Views: 56K
View statistics:
Past 24 Hours:
42
Past 7 Days:
223
Past 30 Days:
867
All Time:
56,178
Comments: 7
7 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 12
12 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Some of Nintendo’s first-batch left Joy-Con controllers are notorious for sync issues. This is due to a minor design flaw, and can be remedied with a small piece of conductive foam that can be often be found in old packaging around the house!
Video Instructions
12 other people completed this guide.
Author
with
Taylor Dixon
73,293 Reputation
94 Guides authored
7 Guide Comments
What thickness of conductive foam should I choose? There are 3 sizes: 3mm/0.12, 5mm/0.20", 10mm/0.39"
maximaleks - Reply Share
The space is ~9 mm wide, so I would go with the 10 mm size and you can trim it down if you need to!
Taylor Dixon - Reply Share
I've got the same problem but with the right joycon but I don't know where the wireless card is, please help
Nathan Currie - Reply Share
Hello I opened up my left joycon and saw conductive foam inside already! I replaced it with one that I bought on amazon (I made sure it was actually conductive foam). But it still won’t sync. Any ideas? Could it be that little solder bubble that connects to the antenna has gone bad? Should I try to reflow it? I also checked to see if any capacitors in the top of the board were shorted and none of them were. If you have any ideas I would be happy to hear!
Chaim Bendahan - Reply Share
I opened my left Joycon and found that there is no antenna area near the joystick compartment. It’s just an empty space what should I do, I have the conductive foam but obviously don’t know where to place.
Omar Gonzalez - Reply Share
Past 24 Hours: 42
Past 7 Days: 223
Past 30 Days: 867
All Time: 56,178
