How to Fix Joy-Con Drift Without Disassembly
    1. How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: step 1, image 1 of 2 How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: step 1, image 2 of 2
      • Press and hold the black round button on the back of the Joy-Con, then slide it forward to remove.
      Ask FixBot
    2. How to Fix Joy-Con Drift Without Disassembly: step 2, image 1 of 2 How to Fix Joy-Con Drift Without Disassembly: step 2, image 2 of 2
      • Open the 404B contact cleaner and insert the tube into the nozzle.
      Ask FixBot
    3. How to Fix Joy-Con Drift Without Disassembly: step 3, image 1 of 1
      • Push the Joy Stick to the side and hold.
      Ask FixBot
    4. How to Fix Joy-Con Drift Without Disassembly: step 4, image 1 of 2 How to Fix Joy-Con Drift Without Disassembly: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to lift the rubber ring under the Joy Stick, and hold.
      Ask FixBot
    5. How to Fix Joy-Con Drift Without Disassembly: step 5, image 1 of 2 How to Fix Joy-Con Drift Without Disassembly: step 5, image 2 of 2
      • Aim the contact cleaner's nozzle at the gap and spray 404B contact cleaner once or twice.
      Ask FixBot
    6. How to Fix Joy-Con Drift Without Disassembly: step 6, image 1 of 3 How to Fix Joy-Con Drift Without Disassembly: step 6, image 2 of 3 How to Fix Joy-Con Drift Without Disassembly: step 6, image 3 of 3
      • Rotate the Joy Stick for 30 seconds to allow full penetration of the liquid inside.
      Ask FixBot
    7. How to Fix Joy-Con Drift Without Disassembly: step 7, image 1 of 1
      • Wait 10 minutes for the liquid to dry completely.
      Ask FixBot
    8. How to Fix Joy-Con Drift Without Disassembly: step 8, image 1 of 3 How to Fix Joy-Con Drift Without Disassembly: step 8, image 2 of 3 How to Fix Joy-Con Drift Without Disassembly: step 8, image 3 of 3
      • Insert the Joy-Con back into the Switch to test the Joy-Con.
      • Navigate to System Settings > Controllers and Sensors > Calibrate Control Sticks.
      • Follow the on-screen prompts on your Switch.
      Ask FixBot
Enjoy your Joy-Con being able to work properly again!
41 other people completed this guide.
Weijie Chen
1,269 Reputation
1 Guide authored
2 Guide Comments
Muchas gracias.
AlmudenaPita - Reply Share
Process says it requires compressed air then goes on to use contact cleaner instead.
Mike Burr - Reply Share
Past 24 Hours: 53
Past 7 Days: 279
Past 30 Days: 1,352
All Time: 114,881
