Up to 20% off select tools
How to Fix E-Paper Tearing
Views: 10K
View statistics:
Past 24 Hours:
9
Past 7 Days:
22
Past 30 Days:
126
All Time:
10,196
Comments: 12
3 comments on steps, 9 guide comments.
Go to guide comments
Completed: 40
40 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This is a guide to fix the E-Paper tearing in Pebble 301BL devices.
*this will void the warranty for the device*
    1. How to Fix E-Paper Tearing, Device: step 1, image 1 of 2 How to Fix E-Paper Tearing, Device: step 1, image 2 of 2
      • This is a guide to fix the E-Paper tearing in Pebble 301BL devices.
      • The Pebble Kickstarter Edition doesn't have screws, it is glued and therefore not repairable without permanent damage.
      Ask FixBot
    2. How to Fix E-Paper Tearing, Remove screws: step 2, image 1 of 1
      Tool used on this step:
      T5 Torx Screwdriver
      $5.49
      Buy
      • Using a T5 Torx screwdriver, remove the 4 screws on the back.
      • When removing the back cover be very gentle! The rumble motor may be adhered to the cover so you must pry it away.
      • iFixit T5 Torx screwdriver
      Ask FixBot
    3. How to Fix E-Paper Tearing, Video connector: step 3, image 1 of 1
      • Locate the video connector near the bottom, right next to the device that vibrates when you get a notification.
      • During normal use, this cable becomes loose and creates the tearing effect.
      • In the next step, you will be shown a way to apply pressure to this and keep it constantly connected.
      Ask FixBot
    4. How to Fix E-Paper Tearing, Apply pressure to Video Connector: step 4, image 1 of 1
      • What worked for me is taking a little toilet tissue or paper towel and placing it over the video connector.
      • One way to test that this will help is by holding a finger on it and cycling through the menus.
      • Nothing inside the device will catch the paper on fire, so there is nothing to worry about.
      Ask FixBot
    5. How to Fix E-Paper Tearing, Closing: step 5, image 1 of 1
      • Once you have confirmed that the paper will apply the necessary pressure, you can then put the screws back in.
      • If the case doesn't seem to close properly as it did before, do not keep on trying to tighten the screw down; you will strip the screw.
      • If the case doesn't close properly, you will need to open the device back up and remove a tiny bit of the paper until it does close, that way it will retain its water resistance.
      Ask FixBot
      • Here is an example of the final result.
      Ask FixBot
40 other people completed this guide.
Author
with
Benjamin Cunliffe
1,794 Reputation
1 Guide authored
9 Guide Comments
This guide sadly only works for the revised model. The kickstarter edition had no screws in the back and have to be pried open from the screen, making the repair next to impossible without badly damaging de case or/and the screen.
gabrielcbnetto - Reply Share
Would something like the iopener work for that? Have had just about every model bar the original ks edition so im not sure myself.
Jayden Waters - Reply Share
It is possible with heat and a ton of patients. Took a buddy of mine a whole afternoon to open it. Once he had the connector reseated, he actually used a of some sort to hold it in place instead so he wouldn't have to have the whole Pebble stuffed. Then he used the same putty/glue to help seal the watch shut. I'll see if he'll tell me what it was.
Zach Hillebrant - Reply Share
"To reassemble your device, follow these instructions in reverse order." .... so take it apart again and remove the tissue?
mlvezie - Reply Share
I see you are trying to be funny.
In case you were serious: no do not remove the tissue.
Benjamin Cunliffe - Reply Share
Past 24 Hours: 9
Past 7 Days: 22
Past 30 Days: 126
All Time: 10,196
