How to Fix Broken Porch Entry Stairs
    1. How to Fix Broken Porch Entry Stairs, Stair treads and risers: step 1, image 1 of 3 How to Fix Broken Porch Entry Stairs, Stair treads and risers: step 1, image 2 of 3 How to Fix Broken Porch Entry Stairs, Stair treads and risers: step 1, image 3 of 3
      • Use a pry bar to remove the pre-existing damaged wood pieces.
      • Start with the riser first.
      • Be mindful of possible rusted screws/nails.
      Ask FixBot
    2. How to Fix Broken Porch Entry Stairs: step 2, image 1 of 3 How to Fix Broken Porch Entry Stairs: step 2, image 2 of 3 How to Fix Broken Porch Entry Stairs: step 2, image 3 of 3
      • Remove the treads on the stairs.
      Ask FixBot
    3. How to Fix Broken Porch Entry Stairs: step 3, image 1 of 2 How to Fix Broken Porch Entry Stairs: step 3, image 2 of 2
      • Use a measuring tape to measure the foundation where the new steps will be placed.
      • To ensure accurate measurements, make sure to repeat this step twice.
      Ask FixBot
    4. How to Fix Broken Porch Entry Stairs: step 4, image 1 of 3 How to Fix Broken Porch Entry Stairs: step 4, image 2 of 3 How to Fix Broken Porch Entry Stairs: step 4, image 3 of 3
      • Mark your measurements on both ends of your new weather treated wood using a measuring tape and a pencil.
      • For the best results, use a ruler to connect your marks into a straight line.
      Ask FixBot
    5. How to Fix Broken Porch Entry Stairs: step 5, image 1 of 1
      • Place the new piece of wood onto the end of a sturdy table.
      • Make sure the marked end is hanging off the edge by at least a foot.
      Ask FixBot
    6. How to Fix Broken Porch Entry Stairs: step 6, image 1 of 1
      • Use a circular saw to cut across the straight line marked on the new piece of wood.
      • Make sure the wood is secure by holding the end resting on the table the entire time.
      • Safety glasses should be worn during this step.
      Ask FixBot
    7. How to Fix Broken Porch Entry Stairs: step 7, image 1 of 2 How to Fix Broken Porch Entry Stairs: step 7, image 2 of 2
      • Place the new piece of wood (riser) on the steps to ensure that it fits.
      • Use a leveler to make sure that it is level.
      Ask FixBot
    8. How to Fix Broken Porch Entry Stairs: step 8, image 1 of 3 How to Fix Broken Porch Entry Stairs: step 8, image 2 of 3 How to Fix Broken Porch Entry Stairs: step 8, image 3 of 3
      • Secure your wood piece (riser) into place using a drill and galvanized screws.
      • Create two pilot holes with the correct drill bit.
      • Secure the wood (riser) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
      Ask FixBot
    9. How to Fix Broken Porch Entry Stairs: step 9, image 1 of 1
      • Make sure your wood piece (tread) fits into place and is level.
      • For the most accurate results, it is important to use a large level.
      Ask FixBot
    10. How to Fix Broken Porch Entry Stairs: step 10, image 1 of 3 How to Fix Broken Porch Entry Stairs: step 10, image 2 of 3 How to Fix Broken Porch Entry Stairs: step 10, image 3 of 3
      • Secure your wood piece (tread) into place using a drill and galvanized screws.
      • Create three pilot holes with the correct drill bit.
      • Secure the wood (tread) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
      Ask FixBot
    11. How to Fix Broken Porch Entry Stairs: step 11, image 1 of 1
      • Repeat steps 8-10 for the remaining stairs.
      • For the best results, follow this guide thoroughly for each stair.
      Ask FixBot
To reassemble your old stairs, follow these instructions in reverse order.
Kayla Unsworth
240 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 35
Past 30 Days: 124
All Time: 10,628
