How to Fix Bicycle Foam Handlebar Grips
  1. How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: step 1, image 1 of 3 How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: step 1, image 2 of 3 How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: step 1, image 3 of 3
    • Assess the problem area on your bike's handlebars.
    Ask FixBot
  2. How to Fix Bicycle Foam Handlebar Grips: step 2, image 1 of 2 How to Fix Bicycle Foam Handlebar Grips: step 2, image 2 of 2
    • Lightly sand down the handlebar with the sandpaper.
    • Continue to sand the handlebar until no more residue falls.
    Ask FixBot
  3. How to Fix Bicycle Foam Handlebar Grips: step 3, image 1 of 2 How to Fix Bicycle Foam Handlebar Grips: step 3, image 2 of 2
    • Boil water in a pot.
    • Once the water reaches boiling temperature (212°F/100°C), dip a rag into the water.
    • Be careful when handling the rag after it has been taken out of the boiling water. Handling the rag too quickly can result in a burn.
    • Take the soaked rag and begin cleaning the handlebar by applying pressure and rubbing in a downwards motion.
    Ask FixBot
  4. How to Fix Bicycle Foam Handlebar Grips: step 4, image 1 of 2 How to Fix Bicycle Foam Handlebar Grips: step 4, image 2 of 2
    • Press a new, clean rag tightly to the opening of the alcohol bottle.
    • Tip the bottle upside down quickly and soak the rag with the alcohol.
    • Once the rag is soaked, start cleaning the handlebar again. Continue to clean the handlebar until there is no more visible residue coming off.
    Ask FixBot
  5. How to Fix Bicycle Foam Handlebar Grips: step 5, image 1 of 2 How to Fix Bicycle Foam Handlebar Grips: step 5, image 2 of 2
    • Finally, bring the water to a boil once more.
    • Dip a rag into the water and begin rubbing the handlebar for the last time. Clean vigorously until the handlebar is noticeably smoother and no longer crumbling with residue.
    Ask FixBot
Following these steps should result in handlebars that feel brand new!
3 other people completed this guide.
Katy Haas
125 Reputation
1 Guide authored
UC Davis, Team S1-G1, Coad Spring 2017 Member of UC Davis, Team S1-G1, Coad Spring 2017
UCD-COAD-S17S1G1
4 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 61
All Time: 6,426
