Up to 20% off select tools
How to Fix Bent Silverware
Views: 4.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
29
Past 30 Days:
142
All Time:
4,818
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your silverware starts to bend, there's no need to go out and buy more. This guide will show you a quick fix to repairing your silverware and bending it back to its original shape.
    1. How to Fix Bent Silverware, How to Fix Bent Silverware: step 1, image 1 of 2 How to Fix Bent Silverware, How to Fix Bent Silverware: step 1, image 2 of 2
      • First, clean with soap and water all of the bent silverware.
      Ask FixBot
    2. How to Fix Bent Silverware: step 2, image 1 of 1
      • Take the pot and fill it halfway with water.
      • Put the pot on the stove and heat the water till it's boiling.
      Ask FixBot
    3. How to Fix Bent Silverware: step 3, image 1 of 1
      • Place the bent silverware in the water for at least one minute.
      Ask FixBot
    4. How to Fix Bent Silverware: step 4, image 1 of 1
      • After the minute is over, carefully pull out all of the silverware using pliers.
      Ask FixBot
    5. How to Fix Bent Silverware: step 5, image 1 of 1
      • Dry off the silverware with either paper or cloth towels. Be careful not to burn yourself.
      Ask FixBot
    6. How to Fix Bent Silverware: step 6, image 1 of 2 How to Fix Bent Silverware: step 6, image 2 of 2
      • Use tools such as pliers, a hard surface, rulers, and/or hammers to reshape silverware as desired.
      Ask FixBot
    7. How to Fix Bent Silverware: step 7, image 1 of 1
      • When your done bending the silverware to its desired shape, let the silverware cool down to stay in that shape.
      Ask FixBot
Finish Line
4 other people completed this guide.
Author
with
Anna Sharpes
256 Reputation
1 Guide authored
1 Guide Comment
What causes the silverware to bend?
Cheddar Cheese - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 142
All Time: 4,818
