How to Fix A Warped Frisbee Disc
    1. How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: step 1, image 1 of 2 How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: step 1, image 2 of 2
      • Place the frisbee disc on a flat surface with the concave side facing up. Lay a towel down flat over the frisbee.
      Ask FixBot
    2. How to Fix A Warped Frisbee Disc: step 2, image 1 of 1
      • Take the bowl and fill halfway full with water. Microwave until water is boiling.
      • The bowl will be hot, so handle it with care.
      Ask FixBot
    3. How to Fix A Warped Frisbee Disc: step 3, image 1 of 1
      • Take the bowl with boiling water and place it on top of the frisbee and the towel.
      Ask FixBot
    4. How to Fix A Warped Frisbee Disc: step 4, image 1 of 1
      • Add a textbook as a weight to sit on top of the bowl.
      • Let everything sit for 1 hour
      Ask FixBot
    5. How to Fix A Warped Frisbee Disc: step 5, image 1 of 1
      • Remove any weights, the bowl, and the towel. Check to see if the disc is still warped.
      • If it is still warped repeat this process one more time.
      Ask FixBot
The time taken to fix the warping on your frisbee may vary based on how thick the plastic is.
3 other people completed this guide.
Bryce Petersen
200 Reputation
1 Guide authored
Cal Poly, Team 30-5, Green Spring 2015 Member of Cal Poly, Team 30-5, Green Spring 2015
CPSU-GREEN-S15S30G5
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 55
All Time: 11,078
