How to Fix A Stripped Screw Hole
    1. How to Fix A Stripped Screw Hole, How to Fix A Stripped Screw Hole: step 1, image 1 of 1
      • Using the toothpick as a reference, measure the depth of the screw-hole and the number of toothpicks needed to fill the screw hole.
      Ask FixBot
    2. How to Fix A Stripped Screw Hole: step 2, image 1 of 2 How to Fix A Stripped Screw Hole: step 2, image 2 of 2
      • Next, using the wood glue, cover the area of the toothpick(s) that will fill in the screw hole.
      Ask FixBot
    3. How to Fix A Stripped Screw Hole: step 3, image 1 of 2 How to Fix A Stripped Screw Hole: step 3, image 2 of 2
      • Place the toothpicks into the screw hole.
      Ask FixBot
    4. How to Fix A Stripped Screw Hole: step 4, image 1 of 1
      • Now, break off the exposed segment of the toothpick(s).
      Ask FixBot
    5. How to Fix A Stripped Screw Hole: step 5, image 1 of 1
      • Clean off the excess and let the wood glue dry for up to 30 minutes.
      • Recommended wood glue drying time may vary by product.
      Ask FixBot
    6. How to Fix A Stripped Screw Hole: step 6, image 1 of 2 How to Fix A Stripped Screw Hole: step 6, image 2 of 2
      • Finally, using the screwdriver, screw the screw into the repaired screw hole.
      Ask FixBot
Your screw should now hold secure.
Isaiah Valdez Mireles
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 50
Past 30 Days: 198
All Time: 3,044
