Introduction
Go to step 1 ↓Many retail stores have a "no returns" rule when it comes to bathing suits. If you find yourself in a situation where you purchased a bikini bottom and it doesn't fit perfectly, but you can't return it, this guide will help. Luckily, this issue can be fixed easily and you will be able to show off and enjoy yourself at the pool in no time.
Once you're finished with the repair you will have a new style bikini bottom that you can adjust to whatever size you choose.
Tools
Use a tape measure to determine the amount of side seam you want to remove so that both sides are the same.
Use sewing scissors to cut 25.4 mm from each side at the seam.
If by the end of this guide your swimsuit is not yet of your liking you can add more elastic to your bikini or choose another style.
