How to Enable developer mode on Chromebook
Views: 101K
View statistics:
Past 24 Hours:
51
Past 7 Days:
429
Past 30 Days:
1,892
All Time:
101,208
Comments: 16
6 comments on steps, 10 guide comments.
Go to guide comments
Completed: 47
47 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
If you want to push your Chrome device beyond its typical capabilities, then you're going to want to enable developer mode. This is the same as gaining root access on your Android device, and gives you significantly more control over your Chromebook. You can do things like sideload Android apps or even install a different operating system onto your Chrome device.
      • Enabling or disabling developer mode will wipe your Chromebook. Your device will be Powerwashed, which means that any accounts and their files will be removed from the device. If you store your data online, then you can log on with the same account afterwards.
      • Officially Google does not offer support for developer mode since it is intended for developers. Enabling developer mode will void most warranties, so if you encounter a hardware error, disable developer mode before getting warranty support.
      • To enable developer mode, you will need to deactivate OS verification. Only turn this on if you are sure of what you are doing!
      Ask FixBot
      • On some older Chromebooks, Developer Mode could be turned on with a physical switch that could be flipped. However, on newer devices you will need to boot the device into Recovery Mode.
      • To start, make sure your Chromebook is on. Then press the Esc and Refresh keys and then press the power button.
      • Normally the refresh key is where the F3 key would be, and is normally the fourth key from the left on the top most row on a keyboard.
      • Your device should take you to a screen that says something along the lines of "Chrome OS is missing or damaged", signifying that you have arrived at the recovery screen.
      Ask FixBot
      • Once you're on the recovery screen, press the Ctrl and D keys.
      • You'll see a screen that says " To turn OS verification OFF, press ENTER". Press enter to enable developer mode.
      • You will see a screen that indicates that OS verification is OFF. (If left long enough the device should beep at you.)
      • This screen is a security feature, as the developer mode doesn't have the usual security features. The screen is meant to help the normal user by guiding them through disabling developer mode if they didn't mean to enable it.
      • To boot your device press the Ctrl and D keys again. Your device should boot automatically and will prepare your system for developer mode. This can take up to 15 minutes.
      Ask FixBot
Congratulations! You now have full and unrestricted access to your Chromebook. If you wish to access a root shell press Ctrl, Alt, and the T keys to open the Crosh shell. From their type shell. You can use this to run commands with the sudo command to run commands with root access.
If you want to return to the standard mode, simply reboot your device and at the warning screen, simply press the space key as prompted. Your device will revet to the factory-default and will erase the files.
47 other people completed this guide.
Jacob Mehnert
50,323 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
70 Members
1,152 Guides authored
10 Guide Comments
the divces owner had turned of developer mode how can i fix this fo
lenovo thinkpad e11 chromebook
Fadi Naddi - Reply Share
The process for disabling developer mode is very similar to enabling it. Turn off your device and turn it back on. When the Chromebook boots and displays the OS verification message, press the Spacebar. This will factory reset the device and return it to its standard configuration.
Jacob Mehnert - Reply Share
Merci, pour le guide alor si cette manipulation (Esc et Refresh, puis appuyez sur le bouton d'alimentation) n'affiche pas l'écran de récupération. Que faire?
Divin - Reply Share
Selon l'âge de votre appareil, la combinaison de touches peut être différente. Sur certains modèles de Chromebook, vous devez appuyer sur les touches Échap et Agrandir et les maintenir enfoncées, puis appuyer sur Alimentation.
What if the last Ctrl+D is not doing anything
Ava Lemburg - Reply Share
Past 24 Hours: 51
Past 7 Days: 429
Past 30 Days: 1,892
All Time: 101,208
