How to Disconnect a Philips Respironics V60
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. How to Disconnect a Philips Respironics V60, shut down the ventilator: step 1, image 1 of 2 How to Disconnect a Philips Respironics V60, shut down the ventilator: step 1, image 2 of 2
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
    Ask FixBot
    • Disconnect the ventilator from the AC power.
    Ask FixBot
    • Unplug the ventilator
    Ask FixBot
  2. How to Disconnect a Philips Respironics V60: step 4, image 1 of 1
    • Disconnect the internal battery from the power harness connector.
    Ask FixBot
Rie Kuraoka
913 Reputation
7 Guides authored
Cal Poly, Team S7-G10, Paton Spring 2020 Member of Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 55
All Time: 383
