How to Defrost and Remove a Refrigerator Icemaker
Views: 1.1K
View statistics:
Past 24 Hours:
11
Past 7 Days:
58
Past 30 Days:
232
All Time:
1,055
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 2 hours
Difficulty: Moderate
Video Guide This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
Ice buildup can lock an icemaker or ice bucket in place, making removal difficult and tempting you to use tools or high heat that can permanently damage plastic parts. This guide covers three safer ways to defrost and free a stuck icemaker on most modern refrigerators: using the refrigerator’s forced defrost mode, using a garment steamer to carve out ice where it’s needed, or using ambient air circulation for a manual defrost. These same principles can also apply when defrosting an evaporator panel behind an ice housing.
Tools
      • Turn the refrigerator off or unplug it before doing any manual defrosting work.
      • Remove food from the refrigerator compartment so you don’t trap warm air and moisture around it.
      • Move freezer food to a cooler if the unit will be off long enough that food safety becomes a concern.
      • Wear work gloves and safety glasses to protect against sharp ice edges and hot steam.
      Ask FixBot
      • Find the refrigerator’s model number and use it to locate the service sheet or tech manual for the unit.
      • Use the tech sheet to identify the diagnostic or service mode steps and any hidden forced defrost codes for the icemaker.
      • If the sheet is missing, search for a model-specific service manual or tech sheet online before forcing any disassembly.
      • Use the exact model number so the service information matches the refrigerator you are working on.
      Ask FixBot
      • Use the refrigerator’s user interface to enter diagnostics or service mode using the model-specific instructions from the tech sheet.
      • Run the icemaker defrost cycle to melt internal buildup and release the icemaker or ice bucket.
      • Stop and switch methods if the icemaker still won’t come free after running the forced defrost routine.
      Ask FixBot
      • Don’t use a hair dryer or a heat gun to defrost an icemaker.
      • High heat can warp thermoplastic parts in the ice bucket, the icemaker housing, or surrounding cabinet structure.
      • A refrigerator traps and pools heat in the icemaker area, increasing the chance of deformation before the ice fully melts.
      • A heat gun test at 350 °F showed exterior temperatures above 100 °F and local temperatures around 250 °F, while the ice barely melted and the plastic began melting.
      Ask FixBot
      • Fill a garment steamer with distilled water.
      • Avoid using tap water because mineral buildup can shorten the steamer’s life and cause problems.
      • Direct steam at the ice around the icemaker or ice bucket to melt ice only where it’s blocking removal.
      • Use the steam like a hot knife to cut channels and break up the ice so the bin can come out.
      • Dump loosened ice into a sink rather than trying to melt all of it inside the cabinet.
      • A steamer can split a 5 inch-thick block of ice in a little over two minutes in a controlled test.
      Ask FixBot
      • Shut the refrigerator off and clear the refrigerator cabinet so air can circulate through the icemaker area.
      • Set up a fan to blow ambient room air into the icemaker compartment to speed defrosting.
      • Moving air is the key, not adding heat.
      • A box fan on low thawed a significant amount of ice in about one hour and reached a similar result to a full day of passive thawing in about three hours.
      • A hair dryer set to cool-only can work as airflow if it truly isn’t heating.
      Ask FixBot
      • Use a tea kettle as a low-budget steam source if needed, but keep the steam directed and controlled.
      • Leave the refrigerator unplugged for about 48 hours if you need a complete passive defrost and can remove and protect all food.
      • Don’t use a screwdriver or any pointed tool to chip ice off an icemaker housing or evaporator panel.
      • Refrigerant lines can run behind these panels, and piercing one can ruin the refrigerator.
      • Don’t strike or pry aggressively out of frustration because it can damage the cabinet, panels, and sealed system.
      Ask FixBot
      • Remove the icemaker or ice bucket only after the ice buildup has melted enough that it releases without force.
      • Use the model-specific service sheet or manual for the exact release method once the unit is unfrozen.
      • Dry any standing water and restore power after the compartment is no longer steaming or wet.
      Ask FixBot
If the icemaker or ice bucket releases cleanly after defrosting, dry the compartment thoroughly and keep watching for returning frost so you can catch any sealing or airflow problem early. If the area freezes up again soon after thawing, the remaining issue is likely in the icemaker housing, fill path, or air-leak pattern rather than just temporary ice buildup. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7,149 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 58
Past 30 Days: 232
All Time: 1,055
