How to Darn a Sock
Views: 3.8K
View statistics:
Past 24 Hours:
15
Past 7 Days:
75
Past 30 Days:
316
All Time:
3,848
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Scenic Route
This guide's procedure isn't the most efficient way to get the job done, but still may be useful in some circumstances.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
How to Darn a Sock
Introduction
Go to step 1 ↓
If you have a hole in your sock and want to fix it, this guide will help repair it through a simple method called darning.
Darning a hole in a sock provides a different outcome than simply sewing up the hole. When you darn a sock, it acts as a replacement for the missing fabric. So, if you have suitable thread types, you can create cool patchwork socks.
A darning mushroom is one of the tools listed. These can be found on Amazon or whichever website you use to purchase goods. If you do not have a darning mushroom or wish to avoid purchasing one, substitutes include tennis balls, light bulbs, or, like in my guide, a water bottle. Essentially, you will need an object inside the sock to stretch out the hole.
Tools
    1. How to Darn a Sock, How to Darn a Sock: step 1, image 1 of 2 How to Darn a Sock, How to Darn a Sock: step 1, image 2 of 2
      • Insert a darning egg (or substitute object) into the sock until the hole is stretched out.
      Ask FixBot
    2. How to Darn a Sock: step 2, image 1 of 2 How to Darn a Sock: step 2, image 2 of 2
      • Sew a running stitch around the hole to reinforce it.
      • To make a running stitch, move your needle in and out of the sock a fixed distance apart.
      • The needle is sharp; use caution and avoid poking your hand.
      Ask FixBot
    3. How to Darn a Sock: step 3, image 1 of 2 How to Darn a Sock: step 3, image 2 of 2
      • Start a stitch from one side of the hole, about ½” to ⅛” away. Connect one side of the hole to the other using the thread.
      • Run parallel stitches until the hole is fully covered.
      Ask FixBot
    4. How to Darn a Sock: step 4, image 1 of 2 How to Darn a Sock: step 4, image 2 of 2
      • Rotate your sock 90 degrees, then repeat step 4 to create a patch.
      Ask FixBot
    5. How to Darn a Sock: step 5, image 1 of 2 How to Darn a Sock: step 5, image 2 of 2
      • Weave the extra thread into the sock's fabric, then cut the needle away from the thread.
      Ask FixBot
Finish Line
justinHo910
145 Reputation
1 Guide authored
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Member of CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 75
Past 30 Days: 316
All Time: 3,848
