How to Create a USB boot drive for Windows 10
    1. How to Create a USB boot drive for Windows 10, Get the Media Creation Tool: step 1, image 1 of 1
      Ask FixBot
    2. How to Create a USB boot drive for Windows 10, Allow in UAC: step 2, image 1 of 1
      • If you have UAC enabled click "Yes"
      Ask FixBot
    3. How to Create a USB boot drive for Windows 10, Accept Ts & Cs: step 3, image 1 of 2 How to Create a USB boot drive for Windows 10, Accept Ts & Cs: step 3, image 2 of 2
      • Click "Accept"
      • Option: Actually read T&Cs
      Ask FixBot
    4. How to Create a USB boot drive for Windows 10, Create installation media: step 4, image 1 of 1
      • Select "Create installation media (USB flash drive, DVD or ISO file) for another PC"
      • Click "Next"
      Ask FixBot
    5. How to Create a USB boot drive for Windows 10: step 5, image 1 of 1
      • If you are creating a USB for another computer take care to get these settings correct for the computer it will be used on. Language is not so important as it can be changed later.
      • If you are creating a back up for the computer you are running the tool on, selecting the check box "Use the recommended options for this PC" will select the settings automatically.
      Ask FixBot
    6. How to Create a USB boot drive for Windows 10: step 6, image 1 of 1
      • Select "USB flash drive"
      • Click "Next"
      • By selecting "ISO file" you can create a disk image that can be burned to a CD or USB at a later date.
      Ask FixBot
    7. How to Create a USB boot drive for Windows 10: step 7, image 1 of 1
      • Now select the USB drive you wish to put the tool on.
      • If your drive does not appear here, make sure it is correctly inserted and detected by Windows.
      Ask FixBot
    8. How to Create a USB boot drive for Windows 10, Download and verify: step 8, image 1 of 3 How to Create a USB boot drive for Windows 10, Download and verify: step 8, image 2 of 3 How to Create a USB boot drive for Windows 10, Download and verify: step 8, image 3 of 3
      • Now windows will download and verify the installation files.
      Ask FixBot
    9. How to Create a USB boot drive for Windows 10, Writing to disk: step 9, image 1 of 2 How to Create a USB boot drive for Windows 10, Writing to disk: step 9, image 2 of 2
      • Now windows will write the installation files to your drive.
      Ask FixBot
    10. How to Create a USB boot drive for Windows 10, Final steps: step 10, image 1 of 2 How to Create a USB boot drive for Windows 10, Final steps: step 10, image 2 of 2
      • Once it's finished writing to the disk click "Next"
      • And after a short wait you're done!
      Ask FixBot
Congratulations on your Windows 10 drive! The flash drive has Windows 10 installed, and you are good to go.
105 other people completed this guide.
Conor Bailey
8,262 Reputation
2 Guides authored
Tech Haus Member of Tech Haus
Business
1 Member
24 Guides authored
22 Guide Comments
Mr. Bailey. How is this Boot drive different from the Recovery drive that I create directly from my PC? Thanks.
John Norton - Reply Share
They do the same thing essentially, they allow you to boot and recover your windows installation. However there is a one difference and that's that, I believe, the recovery drive tool only gives you the option to create a disk for the computer you are using. It's exactly like the recovery partition that some computers and laptops have.
My guide is quite generic in that you could create the disk for any Windows 10 installation.
Thanks for the question.
Conor Bailey - Reply Share
From my practice, UUByte ISO Editor can also create disks for any Windows 10 installation (including Windows 7, Windows 8 and Mac).
And compared with the method shared by Mr. Bailey above, UUByte ISO Editor saves time for users because it only takes 3 steps to create a Windows 10 bootable USB on my PC. It has no difficulty for those new users.
KKEmily - Reply Share
I recommend you add something about how to boot from the USB drive, especially on a machine that has UEFI SecureBoot enabled.
Bill Meacham - Reply Share
I agree that that part of the process is important, however there are so many variables to uefi that writing a coherent guide for that would be difficult. Not to mention that screen shotting those steps a more difficult (although obviously not impossible).
But thank you for the feed back, I'll consider it in the future.
Past 24 Hours: 34
Past 7 Days: 170
Past 30 Days: 619
All Time: 403,191
