Up to 20% off select tools
How to Clean a Flat Iron
Views: 7.5K
View statistics:
Past 24 Hours:
7
Past 7 Days:
39
Past 30 Days:
183
All Time:
7,529
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Does your flat iron not heat up as well as it used to? Does your flat iron have buildup from all the hair product you use? Use this guide to remove accumulated buildup on the plates of your flat iron and improve its heating capabilities.
    1. How to Clean a Flat Iron, How to Clean a Flat Iron: step 1, image 1 of 1
      • Lay out your cloth over your working surface.
      • Set flat iron aside.
      • The Flat Iron should never be plugged in while cleaning.
      Ask FixBot
    2. How to Clean a Flat Iron: step 2, image 1 of 2 How to Clean a Flat Iron: step 2, image 2 of 2
      • Scoop the baking soda (1-3 Tbsp) into your small bowl or cup.
      • You may need more or less baking soda depending on the size of the your iron's plates.
      Ask FixBot
    3. How to Clean a Flat Iron: step 3, image 1 of 2 How to Clean a Flat Iron: step 3, image 2 of 2
      • Add the hydrogen peroxide to the bowl containing the baking soda and stir until a thick paste is formed.
      • Approximately 10 drops of the hydrogen peroxide is needed per tablespoon of the baking soda.
      Ask FixBot
      • The consistency of the paste should be similar to a thick and grainy toothpaste.
      Ask FixBot
    4. How to Clean a Flat Iron: step 5, image 1 of 2 How to Clean a Flat Iron: step 5, image 2 of 2
      • Smear a thick layer of the paste onto the plates of the iron.
      • Let sit for 5 minutes.
      Ask FixBot
    5. How to Clean a Flat Iron: step 6, image 1 of 2 How to Clean a Flat Iron: step 6, image 2 of 2
      • Let the paste sit on the plates for 5 minutes before proceeding.
      • Wipe off the excess but not ALL of the paste with the sponge into the small bowl.
      Ask FixBot
    6. How to Clean a Flat Iron: step 7, image 1 of 1
      • Use your cloth or sponge to scrub the plates of the flat iron until all the buildup is removed.
      • This process may take 2-5 minutes depending on the amount of buildup on your iron.
      Ask FixBot
    7. How to Clean a Flat Iron: step 8, image 1 of 1
      • Once all of the buildup is removed, wipe off all the remaining paste into your bowl.
      Ask FixBot
    8. How to Clean a Flat Iron: step 9, image 1 of 1
      • Dispose the baking soda paste into a sink or trash can.
      • Your Flat Iron is now clean!
      Ask FixBot
Congratulations your flat iron is buildup free!
3 other people completed this guide.
Author
with
Jacquelin
283 Reputation
1 Guide authored
Cal Poly, Team 12-2, Green Winter 2015 Member of Cal Poly, Team 12-2, Green Winter 2015
CPSU-GREEN-W15S12G2
6 Members
72 Guides authored
1 Guide Comment
Any advice on how to clean a heated straightening brush?
bRex - Reply Share
Past 24 Hours: 7
Past 7 Days: 39
Past 30 Days: 183
All Time: 7,529
