How to Clean a Canon PowerShot SD780 IS Shutter Button
    1. How to Clean a Canon PowerShot SD780 IS Shutter Button, How to Clean a Canon PowerShot SD780 IS Shutter Button: step 1, image 1 of 1
      • Before starting, make sure to turn off the camera and remove the battery.
      Ask FixBot
    2. How to Clean a Canon PowerShot SD780 IS Shutter Button: step 2, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the five outermost screws from the camera.
      Ask FixBot
    3. How to Clean a Canon PowerShot SD780 IS Shutter Button: step 3, image 1 of 1
      • Remove the front panel of the camera case to expose the top left ribbon cable. Pull the ribbon cable gently to disconnect it from the camera.
      Ask FixBot
    4. How to Clean a Canon PowerShot SD780 IS Shutter Button: step 4, image 1 of 1
      • Using a Phillips #00 screwdriver remove the single screw on the far left-hand side towards the bottom of the camera.
      Ask FixBot
    5. How to Clean a Canon PowerShot SD780 IS Shutter Button: step 5, image 1 of 1
      • Carefully pull the case apart to separate the 2 pieces.
      • The case will detach from the camera in two pieces.
      Ask FixBot
    6. How to Clean a Canon PowerShot SD780 IS Shutter Button: step 6, image 1 of 1
      • Remove the two screws on the metal plate of the camera case. This will give you access to the spring inside the metal plate for further cleaning.
      • Clean the inside of the camera with a cloth to remove dust and excess grime. This should unstick the shutter button and allow for full function.
      Ask FixBot
Arlene Ale
455 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 1,412
