Up to 20% off select tools
How to Clean Your Car Battery Terminals
Views: 4.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
60
Past 30 Days:
281
All Time:
4,166
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Your car's battery is a vital component of its electrical system, responsible for powering everything from the engine's starter motor to the lights and accessories. Ensuring your battery is in good condition is essential for reliable performance.
We'll cover the essential steps for removing, cleaning, and reassembling a car battery. A well-maintained battery is crucial for a vehicle's performance.
This step-by-step overview will help you keep your car's electrical system in optimal working order, ensuring a smooth and trouble-free driving experience.
Why Clean Your Battery?
When exposed to the elements of nature or neglect, battery terminals will develop corrosion buildup. For example, terminal heads may have a white, blue, or greenish substance with a powdery, granular texture.
The corrosion color depends on what kinds of chemical reactions have occurred. While small amounts of corrosion buildup are harmless, it can cause increasingly severe issues if left untreated. Issues include ignition start-up issues, dead batteries, and in extreme cases battery malfunctions or damage.
Why This Guide is Needed:
Replacement batteries are expensive and you may be able to extend the life of your car battery if you perform maintenance such as this.
Most automobiles' failure to start is from battery issues due to corrosion or improper/loose battery cables.
Lastly, understanding the proper tools, procedures, and dangers of proper battery maintenance will allow you to safely operate your vehicle and possibly save a life.
    1. How to Clean Your Car Battery Terminals, How to Clean Your Car Battery Terminals: step 1, image 1 of 3 How to Clean Your Car Battery Terminals, How to Clean Your Car Battery Terminals: step 1, image 2 of 3 How to Clean Your Car Battery Terminals, How to Clean Your Car Battery Terminals: step 1, image 3 of 3
      • TURN OFF ENGINE, put it in park, and engage the emergency brake. Do not work on the battery with the car on.
      • Pull the hood release in the bottom left of the driver's side of your car.
      • Release the hood safety catch inside the hood.
      • Lift and secure the hood with the hood prop.
      • Organize Required Tools: Wire Brush, Small Combination Wrench, Tech Wipes or Used Rag.
      • By following these steps, you can effectively clean your car battery and maintain a reliable electrical system in your vehicle. Remember to prioritize safety and don't be afraid to ask someone for help.
      Ask FixBot
    2. How to Clean Your Car Battery Terminals: step 2, image 1 of 3 How to Clean Your Car Battery Terminals: step 2, image 2 of 3 How to Clean Your Car Battery Terminals: step 2, image 3 of 3
      • Put on personal protective equipment, including gloves and safety goggles, to shield yourself from battery acid and debris.
      • Carefully inspect the battery for any signs of damage, leaks, or cracks. If the battery is damaged, it should be replaced instead of repaired or cleaned.
      • Use a small adjustable wrench to loosen and remove the negative (-) battery cable first.
      • Handle your tools carefully when near the battery to prevent shock or arcing.
      • Remove the positive (+) cable. Set the cables aside, ensuring they don't accidentally touch the battery terminals or any metal surfaces of the vehicle.
      Ask FixBot
    3. How to Clean Your Car Battery Terminals: step 3, image 1 of 3 How to Clean Your Car Battery Terminals: step 3, image 2 of 3 How to Clean Your Car Battery Terminals: step 3, image 3 of 3
      • Spray the battery cleaner on the terminals and wait a few minutes. Use the wire brush or battery terminal brush to thoroughly scrub corrosion and debris from the metal until the terminals are clean and shiny.
      • Clean inside the battery cable heads which connect to the battery terminals as well.
      • Pay special attention to any visible corrosion or white or greenish deposits. Remove any stubborn corrosion or buildup.
      Ask FixBot
    4. How to Clean Your Car Battery Terminals: step 4, image 1 of 3 How to Clean Your Car Battery Terminals: step 4, image 2 of 3 How to Clean Your Car Battery Terminals: step 4, image 3 of 3
      • Spray CPC on the battery terminals and battery cable heads.
      • DO NOT ingest or get it into your eyes.
      • Apply dielectric grease to battery terminals generously.
      • Coat the washers in dielectric grease if there is any left.
      • Slip washers onto the battery terminals.
      Ask FixBot
    5. How to Clean Your Car Battery Terminals: step 5, image 1 of 2 How to Clean Your Car Battery Terminals: step 5, image 2 of 2
      • Use an adjustable wrench to reconnect the positive (+) cable to the positive (+) battery terminal and tighten it securely.
      • Use an adjustable wrench to reconnect the negative (-) cable to the negative (-) battery terminal and tighten it securely.
      • Double-check that all connections are secure.
      • Account for all of the tools you used and put them away.
      • Start your car to ensure it starts without any issues. Check that all electrical components, such as lights and radio, are functioning correctly.
      Ask FixBot
  1. Reattach the Battery Hold-Down: If your car has a battery hold-down bracket or strap, secure the battery in place. Tighten the bracket or strap to prevent any movement or vibration during driving. If you did not have a battery hold-down skip this step.
  2. Apply Terminal Protection (OPTIONAL):
    • Apply a thin layer of battery terminal grease or petroleum jelly to both the positive and negative terminals. This helps prevent corrosion on the terminals and ensures good electrical contact.
    • After application of grease, slide on anti corrosion washers over battery terminals.
  3. Reconnect the Battery Terminals:
    • Positive Terminal (+): Reconnect the positive (+) battery terminal first. Slide the cable connector over the positive terminal post and tighten the nut securely. Use a wrench to ensure a snug fit, but avoid over-tightening, which could damage the terminal.
    • Negative Terminal (-): Next, reconnect the negative (-) battery terminal. Attach the cable connector to the negative terminal post and tighten the nut securely. Again, use a wrench to ensure a snug fit without over-tightening.
    • Attach Battery Terminal Covers (OPTIONAL): If applicable, any ordered battery covers may be attached if ordered.
  4. Double-Check Connections:
    • Verify that all connections are secure. Ensure the battery is firmly held in place, and the terminals are tightly connected.
  5. Turn On the Vehicle:
    • Start the car to ensure it starts without any issues. Check all electrical components, such as lights, radio, and air conditioning, to make sure they are functioning correctly. This will confirm that the battery is properly reassembled and connected
Author
with
Job Johnson
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 60
Past 30 Days: 281
All Time: 4,166
