How to Clean Stains On A Baking Sheet
Views: 11K
View statistics:
Past 24 Hours:
4
Past 7 Days:
33
Past 30 Days:
156
All Time:
11,326
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 34
34 people have marked this guide "completed." Will you be next?
Favorites: 19
19 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Staining a baking sheet makes the item look worn and filthy. Use this guide to clean your kitchenware quickly and easily.
    1. How to Clean Stains On A Baking Sheet, How to Clean Stains On A Baking Sheet: step 1, image 1 of 1
      • Place the dirty baking sheet on a flat surface.
      • Tip: This method can be used on stained pots and pans as well.
      • Tip: This method works best if you clean the stained baking sheet as soon as it has cooled after use.
      • Note: The liquid on the baking sheet is grease. This method will work whether or not there is grease on the baking sheet
      Ask FixBot
    2. How to Clean Stains On A Baking Sheet: step 2, image 1 of 2 How to Clean Stains On A Baking Sheet: step 2, image 2 of 2
      • Cover the stained part of the baking sheet with a thin layer of baking soda.
      Ask FixBot
    3. How to Clean Stains On A Baking Sheet: step 3, image 1 of 2 How to Clean Stains On A Baking Sheet: step 3, image 2 of 2
      • Pour a small amount of water over the baking soda so the baking soda looks pasty.
      • Tip: Do not put too much water on the baking soda, as it will cause the baking soda to spread and not stay on the desired cleaning area.
      Ask FixBot
    4. How to Clean Stains On A Baking Sheet: step 4, image 1 of 1
      • Set a timer for 15 minutes, press start, and wait until timer goes off.
      Ask FixBot
    5. How to Clean Stains On A Baking Sheet: step 5, image 1 of 2 How to Clean Stains On A Baking Sheet: step 5, image 2 of 2
      • Take a sponge and clean the desired area.
      • Tip: If the baking soda becomes too thick when scrubbing, add more water.
      • Tip: Using the rough side of the sponge makes cleaning easier.
      Ask FixBot
    6. How to Clean Stains On A Baking Sheet: step 6, image 1 of 3 How to Clean Stains On A Baking Sheet: step 6, image 2 of 3 How to Clean Stains On A Baking Sheet: step 6, image 3 of 3
      • Rinse off the baking soda and wash the baking sheet again with soap and water.
      Ask FixBot
Congratulations! You have a baking sheet that looks good as new.
34 other people completed this guide.
Ashlee Takushi
1,210 Reputation
1 Guide authored
Cal Poly, Team 23-5, Green Winter 2015 Member of Cal Poly, Team 23-5, Green Winter 2015
CPSU-GREEN-W15S23G5
4 Members
36 Guides authored
3 Guide Comments
I’ve also had good success getting stains off stainless steel following a similar process but using cream of tartar + vinegar instead of baking soda + water. Cream of tartar with vinegar forms an acidic paste instead of the alkaline paste of the baking soda. Of course, don’t mix these approaches or expect unhelpful frothiness.
Don - Reply Share
Don, thanks for the additional tips, especially the acidic versus alkaline aspects.
Mike Rehbein - Reply Share
is that a non stick baking sheet? How is it on steel?
Christine Shriam - Reply Share
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 156
All Time: 11,326
