How to Check Your iPhone's Battery Health
    1. How to Check Your iPhone's Battery Health, How to Check Your iPhone's Battery Health: step 1, image 1 of 1
      • In order to proceed with this guide, your device must be running iOS 11.3 or higher.
      • Open the Settings app.
      Ask FixBot
    2. How to Check Your iPhone's Battery Health: step 2, image 1 of 1
      • Scroll down and select Battery.
      Ask FixBot
    3. How to Check Your iPhone's Battery Health: step 3, image 1 of 1
      • Select Battery Health.
      Ask FixBot
    4. How to Check Your iPhone's Battery Health: step 4, image 1 of 1
      • Maximum Capacity displays the total charge capacity of the battery compared to when the device was brand new.
      • Over many charge and discharge cycles, this number will gradually drop.
      • Your iPhone should continue to work fine, albeit with shortened battery life. Apple typically recommends replacing the battery once it degrades to 80% or lower.
      Ask FixBot
    5. How to Check Your iPhone's Battery Health: step 5, image 1 of 3 How to Check Your iPhone's Battery Health: step 5, image 2 of 3 How to Check Your iPhone's Battery Health: step 5, image 3 of 3
      • Peak Performance Capability tells you whether your battery can still supply sufficient power for the iPhone's most intense processing tasks. Normal peak performance is what you're aiming for.
      • If it says your iPhone has experienced an expected shutdown, that means your battery couldn't supply the needed power quickly enough, and the system shut down as a result.
      • Your iPhone will throttle its own performance—slowing itself down—in order to prevent further unexpected shutdowns. This can be disabled to manually enable peak performance.
      • Once you disable performance management, you cannot enable it again. It is automatically enabled after an unexpected shutdown.
      • Once your battery falls below a specific threshold (typically 80%), you will be notified that your battery's health is significantly degraded.
      • Follow this guide to replace your iPhone X battery, or click here for other iPhone models.
      Ask FixBot
That's all folks!
29 other people completed this guide.
Josh M
931 Reputation
1 Guide authored
iTech West Palm Beach Member of iTech West Palm Beach
Business
5 Members
12 Guides authored
4 Guide Comments
Battery Health no funciona con las baterías iFixit.
Cambié la batería de mi iPhone 6 por una batería iFixit y no se puede ver el porcentaje de batería máximo. Aparece “reparar“.
Con alguna aplicación de análisis de batería muestra 98%.
Jairo Ochoa - Reply Share
Under “Battery Health,” my iPhone SE says only “Service” and gives none of the information listed here.
Jeremy Nichols - Reply Share
Most likely your battery is below the recommended threshold and should be replaced.
If you replaced your battery, it may continue to say “Service”. I would recommend using a computer app like coconutBattery to check.
Josh M - Reply Share
mine iphone 6 cannot watch battery health
gfght - Reply Share
Past 24 Hours: 20
Past 7 Days: 107
Past 30 Days: 399
All Time: 16,503
