Up to 20% off select tools
How to Check Battery Health Using CROSH
Views: 6.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
43
Past 30 Days:
204
All Time:
6,776
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Like most devices that use a Lithium-ion battery, Chromebook batteries continuously degrade over time. This is typically a result of the fundamental chemistry of the battery, which gives rise to unavoidable chemical reactions which take place inside the battery during runtime. As time goes on, these chemical reactions become less effective; as a result, the battery cannot provide as much power as it used to. Chrome OS does have a way of checking to see if the battery is operating at peak capacity, and can be used to tell if the battery needs to be replaced.
      • From your Desktop use the key combination Ctrl + Alt + T
      Ask FixBot
      • In the CROSH terminal type in battery_test [< test length >]
      • The test length is measured in seconds. if no number is put in, then the test length will default to 300 seconds.
      Ask FixBot
      • You can also use the command battery_firmware info to get additional information about your battery's including serial number, chemistry, and design capacity.
      Ask FixBot
This command is extremely useful for determining if your Chromebook's battery is operating at peak performance, of if there is an issue with the battery.
5 other people completed this guide.
Author
with
Jacob Mehnert
50,876 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
71 Members
1,152 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 43
Past 30 Days: 204
All Time: 6,776
