How to Change to 12V Power Supply
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
50
All Time:
356
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Parts
Tools
      • Remove the modem so only the open-storm board remains. This is to prevent accidentally frying the modem.
      Ask FixBot
      • Remove the JP1 and JP2 jumpers
      Ask FixBot
      • Plug in the 12V power source
      Ask FixBot
      • Using a multimeter, touch the ground to any of the ground pinouts on the board and measure the JP1 and JP2 jumpers
      • You should see 12V on the middle and bottom pin of JP1 and 12V on the bottom pin of JP2. The top pin of JP2 should be ~ 3.6V
      Ask FixBot
      • If ~ 3.6 V measured on top JP2 jumper, then add jumper in new position.
      • JP2 powers the modem so it's very important that it is not supplied the higher voltage, otherwise the modem will fry.
      Ask FixBot
      • Plug in the 12V power supply again and see if the JP2 jumper measures ~ 3.7V
      Ask FixBot
      • Unplug the power source and plug in the modem.
      • Be vary careful to not skip a modem pin when plugging in and that it is oriented in the correct direction.
      • Power back on the board and wait to see a green light on the modem (indicating that it is properly powered and trying to connect to the internet).
      Ask FixBot
To revert back to 3.7V power, flip back the 2 jumpers to how they were at the start of the guide.
Meagan Tobias
154 Reputation
1 Guide authored
Open-Storm Member of Open-Storm
Community
16 Members
288 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 50
All Time: 356
