How to Change an Indoor Doorknob Handle
    1. How to Change an Indoor Doorknob Handle, How to Change an Indoor Doorknob Handle: step 1, image 1 of 1
      • Parts: (in order from left to right)
      • Short Screws
      • Latch mechanism with latch face
      • Long screws
      • Door knob with peg and screw holes (inside of the room)
      • Door knob with screw holes (outside of the room)
      Ask FixBot
    2. How to Change an Indoor Doorknob Handle: step 2, image 1 of 1
      • Face the inside of the knob, you should see two Phillips head screws on either side of the central knob.
      Ask FixBot
    3. How to Change an Indoor Doorknob Handle: step 3, image 1 of 1
      • Unscrew both long screws.
      Ask FixBot
    4. How to Change an Indoor Doorknob Handle: step 4, image 1 of 1
      • Remove the door knob on both sides of the door.
      Ask FixBot
    5. How to Change an Indoor Doorknob Handle: step 5, image 1 of 1
      • You will see the latch face plate (the rectangular piece of metal) where the latch of the door knob is located.
      Ask FixBot
    6. How to Change an Indoor Doorknob Handle: step 6, image 1 of 1
      • Unscrew the two short screws on the latch face plate.
      Ask FixBot
    7. How to Change an Indoor Doorknob Handle: step 7, image 1 of 1
      • Remove the latch face plate and latch mechanism.
      Ask FixBot
    8. How to Change an Indoor Doorknob Handle: step 8, image 1 of 1
      • Push the new latch mechanism with latch face plate into the door.
      • The slanted side of the latch mechanism will be facing the direction that the door closes.
      Ask FixBot
    9. How to Change an Indoor Doorknob Handle: step 9, image 1 of 1
      • Screw in both short screws of the latch face plate.
      Ask FixBot
    10. How to Change an Indoor Doorknob Handle: step 10, image 1 of 1
      • Insert the door knob that goes on the inside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
      Ask FixBot
    11. How to Change an Indoor Doorknob Handle: step 11, image 1 of 1
      • Align the door knob that goes on the outside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
      Ask FixBot
    12. How to Change an Indoor Doorknob Handle: step 12, image 1 of 1
      • Screw in both long screws on both sides of the door knob.
      Ask FixBot
    13. How to Change an Indoor Doorknob Handle: step 13, image 1 of 1
      • Turn the door knob to test your work.
      Ask FixBot
To put the old door knob back on or to change to a different door knob repeat steps from the beginning.
7 other people completed this guide.
Mallory
240 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 74
Past 30 Days: 265
All Time: 11,498
