How to Change a Stretched Canvas
Views: 3.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
114
All Time:
3,493
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 50 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you want to reuse your canvas frame and save your original work, this guide will show you how to remove and replace your stretched canvas.
    1. How to Change a Stretched Canvas, How to Change a Stretched Canvas: step 1, image 1 of 2 How to Change a Stretched Canvas, How to Change a Stretched Canvas: step 1, image 2 of 2
      • Place the canvas upside down on a flat surface.
      Ask FixBot
    2. How to Change a Stretched Canvas: step 2, image 1 of 2 How to Change a Stretched Canvas: step 2, image 2 of 2
      • Place the picker tool under the staple
      • Begin to lift the staple off of the frame by moving the picker tool down towards the table.
      • Lift the staple halfway up (Do not completely remove yet).
      • Don't place your hands directly in front of pointy end of the picker tool.
      Ask FixBot
    3. How to Change a Stretched Canvas: step 3, image 1 of 2 How to Change a Stretched Canvas: step 3, image 2 of 2
      • Once the staple is halfway lifted, use the pliers to completely lift the staple from the frame.
      • Repeat steps 2-3 to remove the rest of staples.
      Ask FixBot
    4. How to Change a Stretched Canvas: step 4, image 1 of 1
      • Roll up your canvas for storage.
      • Roll the canvas with your painting on the outside to avoid cracking
      Ask FixBot
    5. How to Change a Stretched Canvas: step 5, image 1 of 3 How to Change a Stretched Canvas: step 5, image 2 of 3 How to Change a Stretched Canvas: step 5, image 3 of 3
      • Measure out the amount of canvas that is needed to cover the edges of the frame.
      • Once measured, make a small cut in the corner.
      • Use your hands to rip off the excess fabric.
      Ask FixBot
    6. How to Change a Stretched Canvas: step 6, image 1 of 2 How to Change a Stretched Canvas: step 6, image 2 of 2
      • Fold one side of the canvas fabric over the edge of one of the long sides of the frame.
      • While holding the canvas down, use the staple gun to place one staple in the middle
      Ask FixBot
    7. How to Change a Stretched Canvas: step 7, image 1 of 3 How to Change a Stretched Canvas: step 7, image 2 of 3 How to Change a Stretched Canvas: step 7, image 3 of 3
      • Go over to the other side of the frame and use the canvas pliers to grab the canvas fabric. To tighten canvas fabric, begin by holding the pliers at a 45 degree angle then moving the pliers down towards the table.
      • Place the canvas pliers where you intend to place a staple .
      • While holding the fabric down, place a staple in the middle of that side of the frame.
      • Continue Step 7 on the two short sides of the frame.
      Ask FixBot
    8. How to Change a Stretched Canvas: step 8, image 1 of 3 How to Change a Stretched Canvas: step 8, image 2 of 3 How to Change a Stretched Canvas: step 8, image 3 of 3
      • Choose one of the long sides of the frame and begin stapling from the center to about 3 inches away from the corner using the same canvas plier technique from step 7. Then repeat on other long side.
      • Next, repeat this stapling process on the two short sides
      Ask FixBot
    9. How to Change a Stretched Canvas: step 9, image 1 of 2 How to Change a Stretched Canvas: step 9, image 2 of 2
      • Trim the corner of the fabric to make folding easier.
      • The fabric that you cut away should be in the shape of a triangle.
      • Repeat on the other three corners.
      Ask FixBot
    10. How to Change a Stretched Canvas: step 10, image 1 of 3 How to Change a Stretched Canvas: step 10, image 2 of 3 How to Change a Stretched Canvas: step 10, image 3 of 3
      • Choose one corner of the frame and tuck excess fabric inside the fold.
      • Holding tightly onto the fabric, pull the fold up and over the the edge of the frame. Staple to secure both sides of the corner.
      Ask FixBot
    11. How to Change a Stretched Canvas: step 11, image 1 of 2 How to Change a Stretched Canvas: step 11, image 2 of 2
      • When you are finished, stretched canvas should be tight and it should sound like a drum when you tap on it.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 114
All Time: 3,493
