How to Change Strings on a Ukulele
    1. How to Change Strings on a Ukulele, String: step 1, image 1 of 1
      • Start by loosening the string you are trying to replace by twisting the pegs.
      • The G and C tuning pegs turn up to tighten and down to loosen while the E and A tuning pegs turn down to tighten and up to loosen.
      Ask FixBot
    2. How to Change Strings on a Ukulele: step 2, image 1 of 1
      • Next, grab the new string you are using to replace.
      • The packaging will inform you of which string replaces which note—some are different than others so pay attention!
      Ask FixBot
    3. How to Change Strings on a Ukulele: step 3, image 1 of 1
      • Feed the string through the tie block.
      • Remember to leave slack.
      Ask FixBot
    4. How to Change Strings on a Ukulele: step 4, image 1 of 1
      • Wrap the string over the tie block and back underneath itself.
      Ask FixBot
    5. How to Change Strings on a Ukulele: step 5, image 1 of 2 How to Change Strings on a Ukulele: step 5, image 2 of 2
      • Recross the string over itself again, looping it two or three more times.
      Ask FixBot
    6. How to Change Strings on a Ukulele: step 6, image 1 of 1
      • Pinch the string and pull tightly.
      Ask FixBot
    7. How to Change Strings on a Ukulele: step 7, image 1 of 1
      • Now, fasten the string back to the headstock. To do this, feed the string through the hole in the turning peg.
      Ask FixBot
    8. How to Change Strings on a Ukulele: step 8, image 1 of 1
      • Twist again to tighten and cut off extra string once complete.
      Ask FixBot
Finish Line
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 63
All Time: 1,290
