How to Change Broken Buttons on your Lexus Key Fob
  1. How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: step 1, image 1 of 2 How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: step 1, image 2 of 2
    • Place the key fob with the removable metal key facing towards you.
    Ask FixBot
  2. How to Change Broken Buttons on your Lexus Key Fob: step 2, image 1 of 3 How to Change Broken Buttons on your Lexus Key Fob: step 2, image 2 of 3 How to Change Broken Buttons on your Lexus Key Fob: step 2, image 3 of 3
    • With the button side facing you, pull the metal latch down towards you to pull out the key.
    Ask FixBot
  3. How to Change Broken Buttons on your Lexus Key Fob: step 3, image 1 of 3 How to Change Broken Buttons on your Lexus Key Fob: step 3, image 2 of 3 How to Change Broken Buttons on your Lexus Key Fob: step 3, image 3 of 3
    • With the exposed corner facing you, place the metal key into the slot.
    • Turn the key sideways to open the key fob.
    • You may feel like you're breaking the key fob, but be firm while twisting.
    Ask FixBot
  4. How to Change Broken Buttons on your Lexus Key Fob: step 4, image 1 of 2 How to Change Broken Buttons on your Lexus Key Fob: step 4, image 2 of 2
    • Remove the motherboard and battery to access the buttons.
    Ask FixBot
  5. How to Change Broken Buttons on your Lexus Key Fob: step 5, image 1 of 3 How to Change Broken Buttons on your Lexus Key Fob: step 5, image 2 of 3 How to Change Broken Buttons on your Lexus Key Fob: step 5, image 3 of 3
    • Rotate the front plate, the broken buttons should fall out with ease.
    • Replace the broken buttons as necessary.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Apply firm pressure when snapping the front and back covers together.
7 other people completed this guide.
Michael Tan
590 Reputation
3 Guides authored
Cal Poly, Team 30-3, Green Spring 2015 Member of Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Members
10 Guides authored
1 Guide Comment
useless guide
Davide - Reply Share
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 104
All Time: 7,312
