How to Calibrate Steam Deck Triggers
Views: 31K
View statistics:
Past 24 Hours:
15
Past 7 Days:
107
Past 30 Days:
444
All Time:
31,021
Comments: 17
5 comments on steps, 12 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to calibrate your Steam Deck's triggers from within SteamOS.
Valve recommends performing this software calibration after installing new triggers.
NOTE: Both Steam Deck thumbstick and trigger calibrations may not function in SteamOS version 3.3.
    1. How to Calibrate Steam Deck Triggers, Open Konsole: step 1, image 1 of 2 How to Calibrate Steam Deck Triggers, Open Konsole: step 1, image 2 of 2
      • If you're not already in desktop mode, navigate to the Steam Menu → Power, and select Switch to Desktop.
      • If you don't have a keyboard plugged into your Steam Deck, you'll need to use the on-screen keyboard.
      • Press the Steam Button + X to enable the on-screen keyboard.
      • Trigger calibration is done within a terminal window using SteamOS's console, named Konsole.
      • From the Search menu, search for and open Konsole.
      • If you need to, move the Konsole window so your on-screen keyboard doesn't obscure it.
      Ask FixBot
    2. How to Calibrate Steam Deck Triggers, Start the trigger calibration: step 2, image 1 of 1
      • Within Konsole, type trigger_cal.
      • Alternatively, type trig and then press Tab to auto-complete.
      • Press Enter.
      Ask FixBot
    3. How to Calibrate Steam Deck Triggers, Perform the trigger calibration: step 3, image 1 of 2 How to Calibrate Steam Deck Triggers, Perform the trigger calibration: step 3, image 2 of 2
      • The software will first calibrate the triggers' non-depressed resting position.
      • Ensure that neither trigger is depressed. Press Enter.
      • The software will now calibrate the triggers' fully-depressed position.
      • Tap on a blank desktop area to move the cursor off of the Konsole window. Make sure Konsole isn't in focus.
      • Gently press down each trigger until they bottom out.
      • Don't apply too much force or the triggers could be incorrectly calibrated.
      • Tap on the Konsole window to bring focus back to it. Press Enter.
      • That's it! Your triggers are now calibrated. The terminal should say "Trigger calibration successful."
      Ask FixBot
Click here to return to the left trigger replacement guide. Click here to return to the right trigger replacement guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
10 other people completed this guide.
Carsten Frauenheim
171,659 Reputation
441 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
12 Guide Comments
Do you need to enable developer mode or download anything to get this working? All I get is 'command not found' when I try to run trigger_cal_v1_1.
sudoWiz - Reply Share
Same, hoping this gets looked at and resolved.
Philip Kellett - Reply Share
all i get is :permission denied" anytime i try this, please update the guide
Garrett Hart - Reply Share
trigger_cal is located in /usr/bin/trigger_cal but is not executable. Here's what I did:
cp /usr/bin/trigger_cal ~/
chmod u+x
./trigger_cal
Ben Jackel - Reply Share
This is an incomplete guide when it doesn't explain the permission error when executing trigger_cal
Tim Mok - Reply Share
Past 24 Hours: 15
Past 7 Days: 107
Past 30 Days: 444
All Time: 31,021
