How to Bind a Book Spine
    1. How to Bind a Book Spine, How to Bind a Book Spine: step 1, image 1 of 1
      • First, grab the book you would like to fix.
      Ask FixBot
    2. How to Bind a Book Spine: step 2, image 1 of 1
      • Then, open the book to where you have the most access to the exposed inner spine.
      Ask FixBot
    3. How to Bind a Book Spine: step 3, image 1 of 1
      • Shake up the glue before removing the cap.
      • Then, test glue on a piece of paper before placing it on the spine of the book. It should be about the consistency of Elmer's glue.
      Ask FixBot
    4. How to Bind a Book Spine: step 4, image 1 of 1
      • Place the glue along the spine opposite of the cover. Make sure you are distributing glue evenly.
      • You may also choose to use a paint brush to make sure area is completely covered with glue.
      • Glue is runny; use with caution.
      Ask FixBot
    5. How to Bind a Book Spine: step 5, image 1 of 1
      • After placing the glue, wrap the cover tightly around the book.
      • Firmly drag your fingers down the spine of the book to avoid any air pockets.
      • Remove any excess glue with a tissue.
      • For the demonstration we held the book as shown. You may also choose to place something on top of the book, such as a paperweight or another book, and let it sit for 30 to 40 minutes.
      Ask FixBot
    6. How to Bind a Book Spine: step 6, image 1 of 1
      • After the glue is dry, you should be able to lightly tug on the pages without any movement.
      • If movement occurs then allow the glue an additional 10 to 15 minutes to dry. Once dry, you've completed your book repair.
      Ask FixBot
2 other people completed this guide.
Britne Misner
149 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 48
Past 30 Days: 130
All Time: 3,166
