How to Adjust a Buttonhole Size
Views: 9.9K
View statistics:
Past 24 Hours:
8
Past 7 Days:
61
Past 30 Days:
279
All Time:
9,944
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 30 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Do you have a shirt with one button that always comes unbuttoned? If so, you need to shorten that buttonhole.
Would you like to change the look of a garment by changing all the buttons to new ones? To do this, you may need to shorten or lengthen the buttonholes.
Adjusting buttonholes is not difficult. This guide will show you the steps to this useful skill.
Parts
Tools
    1. How to Adjust a Buttonhole Size, How to Adjust a Buttonhole Size: step 1, image 1 of 3 How to Adjust a Buttonhole Size, How to Adjust a Buttonhole Size: step 1, image 2 of 3 How to Adjust a Buttonhole Size, How to Adjust a Buttonhole Size: step 1, image 3 of 3
      • Steps 1-3 demonstrate how to shorten a buttonhole when the button will not stay buttoned or needs to be replaced with a smaller button.
      • Using the ruler, measure the button you intend to use. Add 1/8” to this measurement for ease of buttoning.
      Ask FixBot
    2. How to Adjust a Buttonhole Size: step 2, image 1 of 1
      • Measure down from the top of the existing buttonhole to the length of your Step 1 measurement.
      • Make a small sewing chalk mark or insert a straight pin to mark how long your adjusted buttonhole should be.
      Ask FixBot
    3. How to Adjust a Buttonhole Size: step 3, image 1 of 3 How to Adjust a Buttonhole Size: step 3, image 2 of 3 How to Adjust a Buttonhole Size: step 3, image 3 of 3
      • Use either a sewing machine or needle and thread for this step.
      • Match the stitch width of the existing bar tack, and sew a new bar tack at the location of your chalk mark.
      • A bar tack is several long, narrowly spaced stitches that form the top of a T between shorter perpendicular stitches.
      • Check to make sure your button fits your adjusted buttonhole well.
      Ask FixBot
    4. How to Adjust a Buttonhole Size: step 4, image 1 of 2 How to Adjust a Buttonhole Size: step 4, image 2 of 2
      • Steps 4-8 demonstrate how to lengthen a buttonhole if it is too tight for your button or if you want to sew on larger buttons.
      Ask FixBot
    5. How to Adjust a Buttonhole Size: step 5, image 1 of 3 How to Adjust a Buttonhole Size: step 5, image 2 of 3 How to Adjust a Buttonhole Size: step 5, image 3 of 3
      • With the ruler, measure down from the top of the existing buttonhole to the length of your Step 4 measurement.
      • Make a small sewing chalk mark or insert a straight pin on the fabric at this place.
      Ask FixBot
    6. How to Adjust a Buttonhole Size: step 6, image 1 of 2 How to Adjust a Buttonhole Size: step 6, image 2 of 2
      • Starting on the right of the existing buttonhole, stitch to your chalk mark or pin, matching the width of the original stitching.
      • Stitch a new bar tack.
      • Stitch back on your left to just past the original bar tack.
      • Tie off or backstitch your thread.
      Ask FixBot
    7. How to Adjust a Buttonhole Size: step 7, image 1 of 1
      • Using the point of your scissors, cut through the original bar tack and between your new side stitching until you have reached the new bar tack.
      • Do not cut through your new bar tack.
      Ask FixBot
    8. How to Adjust a Buttonhole Size: step 8, image 1 of 2 How to Adjust a Buttonhole Size: step 8, image 2 of 2
      • If using the existing button, you may have to cut it off and move it slightly to be centered in the larger buttonhole and resew it on.
      • Very near the place where your button was originally sewn on, center your button in your adjusted buttonhole. Using chalk or a pin, mark this location.
      • Sew your button on.
      • Check to make sure it fits through your adjusted buttonhole well.
      Ask FixBot
A sewing machine with a buttonhole presser foot is ideal, but this project can be completed with needle and thread.
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 61
Past 30 Days: 279
All Time: 9,944
