How to Access the Service Program in Your DeLonghi Coffee Maker
Video Guide
This guide was transcribed from a YouTube video.
Video Overview
    • Press buttons 2 and 4 simultaneously, then power on coffee maker.
    • The power is usually a toggle switch on the back or bottom edge. In rare cases, you'd just have to plug in the machine to connect power.
    Ask FixBot
    • This is optional, but if you'd like to keep the machine open to see what exactly is happening during the testing, you may wish to create a bypass, e.g. such a little tube, which simulates the mandrel so that the machine has the feeling that it is closed.
    • That's possible to do with many machines, and I find it useful.
    Ask FixBot
    • To move the brewing unit up, press buttons 2 and 3.
    • You can now observe the brewing unit moving upwards until it stops automatically.
    • Now it goes to the brew position until it reaches the top of the microswitch and then it stops automatically.
    • You may repeat the process as often as necessary for you to find out e.g. if the lifting function is working at all.
    Ask FixBot
    • With the brewing unit in position, press button 4 to start the water pump.
    • Observe the water flow to identify any potential leaks.
    • Especially with Saeco machines, it happens very often that they're leaking.
    • After having checked that there's nothing wrong with the drain, you may use this method to find out if the leak is somewhere on the brewing unit or on the spigot seals that dock here.
    • Use a flashlight to see clearly and check if it's all really tight.
    Ask FixBot
    • Be aware that safety features may be bypassed in service mode.
    • Remove your fingers from moving parts to prevent injury.
    • Remember, working in service mode exposes you to the internal mechanics of the coffee maker.
    Ask FixBot
    • To exit, disconnect the power, then plug it back in and restart the coffee maker.
    Ask FixBot
Still not found what's wrong? Try some basic troubleshooting, or ask our Answers community for help.
eCuration
476,944 Reputation
385 Guides authored
iFixit Member of iFixit
Staff
123 Members
29,508 Guides authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 59
Past 30 Days: 292
All Time: 3,755
