Up to 20% off select tools
How to Access GE Washing Machine Error Code Mode
Views: 12K
View statistics:
Past 24 Hours:
36
Past 7 Days:
184
Past 30 Days:
723
All Time:
12,353
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Video Guide
This guide was transcribed from a YouTube video.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to enter error code mode and field service mode on select GE washing machines. These built-in diagnostics can help you confirm faults such as water supply problems, door lock errors, and out-of-balance conditions before you replace parts.
      • Unplug the washing machine for about five minutes and then reconnect power.
      • Ensure the display is blank and no cycle is running before proceeding.
      Ask FixBot
      • Press and hold the Start/Pause button for 10 seconds until the display lights up.
      • Release the button when the first stored code appears.
      Ask FixBot
      • Press Start/Pause again to cycle through each stored error code.
      • Two horizontal lines on the display mean you have reached the end of the list.
      Ask FixBot
      • Press any button on the right side of the control panel except Start or Power.
      • Confirm the display shuts down and the washer exits error code mode.
      Ask FixBot
      • Compare the code on the display with GE's fault list.
      • Use that code to focus your troubleshooting before replacing parts.
      Ask FixBot
      • Press and hold the Start button while rotating the selector knob 180 degrees counterclockwise.
      • Release Start when the display begins flashing.
      • If you overshoot slightly, return the knob to its starting position and try again.
      Ask FixBot
      • Turn the knob clockwise to increase the test number or counterclockwise to decrease it.
      • Press Start once to begin the selected test.
      • Test 1 returns to the stored error code mode from the earlier steps.
      Ask FixBot
      • Press and hold Start/Pause for 10 seconds to reset the washer.
      • Confirm the display returns to normal operation afterward.
      Ask FixBot
      • Check for alerts such as H2O Supply when water flow is restricted or turned off.
      • Watch for a door alert if the washer does not sense a closed or locked lid.
      • If the spin light blinks, rebalance the load and inspect for out-of-balance conditions.
      • If the display shows Cancelled, close the lid and try again, or power-cycle the washer if needed.
      Ask FixBot
      • Record the stored codes and any service-test results before making repairs.
      • Future models may add more test numbers, but the basic entry steps are usually the same.
      Ask FixBot
Use the stored codes and service tests to narrow the fault before replacing parts. Exit diagnostics when you're done and return the washer to normal operation. Repair didn't go as planned? Ask our Answers community for help.
3 other people completed this guide.
Author
with
Ben Schlichter
7,269 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 36
Past 7 Days: 184
Past 30 Days: 723
All Time: 12,353
