Introduction
Use the hidden service mode on a Hotpoint washer to read stored fault codes, run built-in tests, and reference the technician sheet. This is a good starting point when the washer won't run correctly and you need model-specific troubleshooting information.
Step 1 Confirm the console light layout
Check that the control panel uses the same style and orientation of indicator lights shown in the video before following the light-based code instructions.
Step 2 Locate the hidden technician sheet
Look for the hidden technician sheet near the back left corner of the washer.
Tilt the washer against a wall and check underneath that back left corner for the manual.
Step 3 Enter service mode
Press and hold the Start/Pause button.
Keep holding Start/Pause while turning the cycle dial clockwise seven clicks (increments).
Release the Start/Pause button when the dial is on the seventh increment.
Confirm service mode is active by checking that all console lights flash on and off at the same time (from Deep Rinse Fill through Lid Locked).
Step 4 Navigate and run service tests
Turn the dial clockwise to move forward through the service test numbers.
Turn the dial counterclockwise to move backward through the service test numbers.
Press the Start/Pause button to activate the currently selected service mode and observe the function the mode is meant to operate.
Step 5 View stored fault codes using the lights
Select service mode number one (fault codes).
Press the Start/Pause button to display a fault code using a flashing-light sequence.
Read the flashing lights as a binary code sequence and match it to the fault-code chart in the technician sheet.
Press the Start/Pause button repeatedly to scroll through any additional stored failures.
Exit the fault-code display by turning the dial to the next service mode.
Step 6 Use the technician sheet for model-specific mode counts and codes
Use the technician sheet from your washer to confirm the exact number of service modes and the exact fault-code meanings for your model.
Exit service mode after testing and use the technician sheet for model-specific fault-code follow-up. Repair didn't go as planned? Ask our Answers community for help.
