How do I replace a broken segment of my tent pole?
    1. How do I replace a broken segment of my tent pole?, Broken segment of  tent pole: step 1, image 1 of 2 How do I replace a broken segment of my tent pole?, Broken segment of  tent pole: step 1, image 2 of 2
      • Loosen the shock cord between the last good segment and the broken segment so that you can remove the pin from the end.
      Ask FixBot
      • Attach the shock cord to a clothes pin or similar item.
      Ask FixBot
    2. How do I replace a broken segment of my tent pole?: step 3, image 1 of 2 How do I replace a broken segment of my tent pole?: step 3, image 2 of 2
      • Pull the pin out of the segment.
      Ask FixBot
    3. How do I replace a broken segment of my tent pole?: step 4, image 1 of 1
      • Cut off the knot.
      Ask FixBot
    4. How do I replace a broken segment of my tent pole?: step 5, image 1 of 1
      • Remove the shock cord from the broken segment.
      • If the broken segment is in the middle of the tent pole, you have to first remove the good segment(s). Take care to keep the pole segments in the same order when reassembling the tent pole, numbering them if necessary.
      Ask FixBot
    5. How do I replace a broken segment of my tent pole?: step 6, image 1 of 3 How do I replace a broken segment of my tent pole?: step 6, image 2 of 3 How do I replace a broken segment of my tent pole?: step 6, image 3 of 3
      • To determine which replacement segment to order, measure the outer diameter of the pole and of the tapered end.
      • A caliper makes it easier to measure the diameter. If you don’t have one on hand, you can use a normal measuring tape.
      Ask FixBot
    6. How do I replace a broken segment of my tent pole?: step 7, image 1 of 2 How do I replace a broken segment of my tent pole?: step 7, image 2 of 2
      • Transfer the length of the broken segment to the new segment. Start measuring after the tapered end, and mark the length with a marker.
      Ask FixBot
    7. How do I replace a broken segment of my tent pole?: step 8, image 1 of 1
      • Put the pole segment into a vice and saw it off at the correct length.
      Ask FixBot
    8. How do I replace a broken segment of my tent pole?: step 9, image 1 of 2 How do I replace a broken segment of my tent pole?: step 9, image 2 of 2
      • File off any sharp ends using the round file on the inside and the flat file for the outer edges.
      Ask FixBot
      • Rethread the shock cord through the segment. Tie the end of the shock cord to the pin and thread the other end through the pole.
      Ask FixBot
Finish Line
Special thanks to these translators:
de en
100%
VAUDE Reparaturteam is helping us fix the world! Want to contribute?
Start translating ›
VAUDE Reparaturteam
6,767 Reputation
32 Guides authored
Vaudesport Member of Vaudesport
Community
3 Members
540 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 110
All Time: 3,689
