How To Stop Sony HDR-CX240E Screen From Moving
  1. How To Stop Sony HDR-CX240E Screen From Moving, Unscrewing The Right Panel: step 1, image 1 of 1
    • Unscrew the 2 Phillips #00 screws on the right side of the camera.
    Ask FixBot
  2. How To Stop Sony HDR-CX240E Screen From Moving, Unscrewing the bottom: step 2, image 1 of 1
    • Unscrew the 4 Phillips #00 screws form the bottom of the camera.
    Ask FixBot
  3. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Battery Compartment Cover: step 3, image 1 of 1
    • Remove the battery compartment cover by pulling it while "wiggling" it. It works like a hook.
    Ask FixBot
  4. How To Stop Sony HDR-CX240E Screen From Moving, Unscrewing The Left Panel: step 4, image 1 of 2 How To Stop Sony HDR-CX240E Screen From Moving, Unscrewing The Left Panel: step 4, image 2 of 2
    • Unscrew the 2 Phillips #00 screws from the left side.
    • Unscrew the Phillips #00 screw from the small SD and HDMI compartment on the left side.
    Ask FixBot
  5. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Small Back Panel: step 5, image 1 of 1
    • Using the opening tool, remove the small panel at the back of the camera.
    • Always be careful when removing any panel, so you don't break any clips.
    Ask FixBot
  6. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Right Panel: step 6, image 1 of 1
    • Carefully use the opening tool or guitar picks to remove the entire right panel from the camera.
    Ask FixBot
  7. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Right Lens Small Panel: step 7, image 1 of 1
    • Pry the tiny panel off of the left side of the lens, between the lens and the screen hinge, revealing the hinge.
    Ask FixBot
  8. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Lens Ring And Cover Ring: step 8, image 1 of 1
    • Remove the plastic lens cover, and then remove the inside black "ring" that also contains the lens protector.
    Ask FixBot
  9. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Last Lens Ring And Mic: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the last ring from around the lens, very carefully as the microphone is on it, which is connected with a ribbon cable to the camera.
    • Remove the ring carefully, since it is connected to the motherboard with a ribbon cable.
    • Then, use a pair of tweezers to carefully disconnect the ribbon cable from the board.
    Ask FixBot
  10. How To Stop Sony HDR-CX240E Screen From Moving, Separating The Two Parts Of The Camera: step 10, image 1 of 1
    • Unscrew the Phillips #00 screw from the left side of the lens, next to the hinge.
    Ask FixBot
  11. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Lens: step 11, image 1 of 1
    • Unscrew the 3 Phillips #00 screws from around the lens of the camera.
    • Then, remove the lens using your tweezers.
    • Handle the lens with caution as it's fragile.
    • It might be a good time to clean the lens with a microfiber cloth since you've already opened the camera.
    Ask FixBot
  12. How To Stop Sony HDR-CX240E Screen From Moving, Screwing The Hinge: step 12, image 1 of 1
    • Tilt the camera to the side of the screen.
    • Pull apart the 2 sides of the camera to make some space.
    • Don't pull the 2 sides apart with too much force!
    • Using your Phillips #00 screwdriver, carefully screw tightly the 2 screws that hold the hinge on the camera.
    • You will need to use your screwdriver "diagonally" (not straight), since having clear access to the screws would require a lot more disassembly.
    Ask FixBot
Stratos Thivaios
1,453 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 35
All Time: 739
