Up to 20% off select tools
How To Silence MrCool Mini Split Buzzer
Views: 7.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
41
Past 30 Days:
128
All Time:
7,370
Comments: 8
2 comments on steps, 6 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Request Guide Deletion
This guide will be reviewed by admins for deletion.
Community-Contributed Guide
Introduction
Go to step 1 ↓
The MrCool mini-split AC air handler has a beeper buzzer that you cannot disable via software or remote. Follow these directions to remove the buzzer.
    1. How To Silence MrCool Mini Split Buzzer, How To Silence MrCool Mini Split Buzzer: step 1, image 1 of 1
      • Turn off the power to the unit at the circuit breaker. Lift up to open the front cover of the air handler as if you were going to clean the air filters.
      Ask FixBot
    2. How To Silence MrCool Mini Split Buzzer: step 2, image 1 of 1
      • Pry off the plastic cover on the right of the unit using the supplied pry-hole.
      Ask FixBot
    3. How To Silence MrCool Mini Split Buzzer: step 3, image 1 of 1
      • Disconnect the ribbon cable that connects the front cover to the main body of the air handler.
      Ask FixBot
    4. How To Silence MrCool Mini Split Buzzer: step 4, image 1 of 1
      • Push outwards on the cover hinge arms to release the plastic hinges; the front cover should lift away from the main unit.
      Ask FixBot
    5. How To Silence MrCool Mini Split Buzzer: step 5, image 1 of 2 How To Silence MrCool Mini Split Buzzer: step 5, image 2 of 2
      • Use a Phillips head screwdriver to remove three screws from the front of the unit. The middle screw is hidden under a small plastic flap (see second photo).
      Ask FixBot
    6. How To Silence MrCool Mini Split Buzzer: step 6, image 1 of 1
      • Gentelly pull up on the top of the white plastic housing to release the housing from the main unit. Release six small clips from the top before the white housing releases from the unit. Once the clips on top are released, pull the white cover away from the wall while rotating it forward (roll it away from the wall).
      Ask FixBot
    7. How To Silence MrCool Mini Split Buzzer: step 7, image 1 of 1
      • Use a Philips screwdriver to remove the screw at the top right of the unit, holding the control box in place.
      Ask FixBot
    8. How To Silence MrCool Mini Split Buzzer: step 8, image 1 of 1
      • Pull the control box away from the unit, rotating it clockwise to reveal the back of the control box, which was facing into the unit.
      Ask FixBot
    9. How To Silence MrCool Mini Split Buzzer: step 9, image 1 of 1
      • Release plastic clips to remove the metal shielding from the side of the control box that was facing into the unit.
      Ask FixBot
    10. How To Silence MrCool Mini Split Buzzer: step 10, image 1 of 1
      • Release more plastic clips to remove the plastic casing that covers the main PCB.
      Ask FixBot
    11. How To Silence MrCool Mini Split Buzzer: step 11, image 1 of 1
      • Locate the piezo buzzer on the main PCB and pull on the top half of it with your fingers or with a pair of needle-nose pliers to remove the top half of the buzzer.
      Ask FixBot
    12. How To Silence MrCool Mini Split Buzzer: step 12, image 1 of 1
      • With the top half of the buzzer removed, your unit will now be silent. Repeat steps backwards to reassemble.
      Ask FixBot
11 other people completed this guide.
Author
with
pier555
520 Reputation
1 Guide authored
6 Guide Comments
I didn't want to make a permanent change or risk damaging anything, so instead of removing the buzzer, I put a cut piece of paper cotton swap stick in the hole of the buzzer and dabbed some hot glue on top. This made the beep barely perceptible.
Thank you for the guide!
Avery Larsen - Reply Share
Thanks for the info! I made a video on how to do this.
https://www.youtube.com/watch?v=ttLZ0GEP...
Argent - Reply Share
I do recommend against doing this as the beeping can warrant any of the following: A dirty air filter, malfunctioning thermostat, Frozen evaporator coils, Low refrigerant levels, or Electrical issues
Removing the buzzer may prevent a user from knowing about any underlying issues the machine is detecting and may cause further damage to the machine if the issue is not diagnosed
Medical - Reply Share
Can't believe this cannot be disabled for temp changes, not when errors or faults happen. This is a Firmware update need
Allister T - Reply Share
Great guide.
Mark Muse - Reply Share
Past 24 Hours: 4
Past 7 Days: 41
Past 30 Days: 128
All Time: 7,370
