Up to 20% off select tools
How To Sew With An Awl
Views: 23K
View statistics:
Past 24 Hours:
10
Past 7 Days:
74
Past 30 Days:
332
All Time:
22,788
Comments: 0
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 34
34 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Parts
Tools
Introduction
Go to step 1 ↓
An awl is a tool that allows you to sew through very thick materials. It takes a bit of practice to master, but once you have it down you'll be ready to repair boots, webbing, and packs on the fly.
Return to the Patagonia Care & Repair homepage.
    1. How To Sew With An Awl, How To Sew With An Awl: step 1, image 1 of 2 How To Sew With An Awl, How To Sew With An Awl: step 1, image 2 of 2
      • Loosen the awl by holding the smooth end and twisting the ridged piece counterclockwise.
      Ask FixBot
    2. How To Sew With An Awl: step 2, image 1 of 3 How To Sew With An Awl: step 2, image 2 of 3 How To Sew With An Awl: step 2, image 3 of 3
      • Insert the needle into the ridged end of the awl, with the eye facing outward.
      • Retighten the awl by holding the smooth end and twisting the ridged end clockwise.
      • Insert the cotter pin into the hole in the smooth end.
      • The cotter pin provides a nice handle for working with the awl.
      Ask FixBot
    3. How To Sew With An Awl: step 3, image 1 of 2 How To Sew With An Awl: step 3, image 2 of 2
      • Thread the needle with very thick thread.
      • Align your material. In this case we are resewing the webbing holding a buckle in place.
      Ask FixBot
    4. How To Sew With An Awl: step 4, image 1 of 2 How To Sew With An Awl: step 4, image 2 of 2
      • Stab the threaded needle of the awl through all the layers of fabric you are sewing.
      • Thick material is very hard to puncture. Be careful not to puncture yourself in the process.
      • If you are having difficulty puncturing the material, you can use a vice to hold the material in place, or place something on the backside of the material to puncture into. A rubber eraser works great.
      Ask FixBot
    5. How To Sew With An Awl: step 5, image 1 of 2 How To Sew With An Awl: step 5, image 2 of 2
      • Pull the short end of the thread through the material, so that it dangles free on the other side of the material.
      Ask FixBot
    6. How To Sew With An Awl: step 6, image 1 of 2 How To Sew With An Awl: step 6, image 2 of 2
      • While holding on to the short, free end of the thread, carefully pull the awl back through the material.
      • The short, free end of the thread should stay on the other side of the material.
      • Continue holding the short, free thread, and puncture the material again a short distance away, moving along the material you are sewing.
      • This distance will become a stitch. Try to keep your stitch length short and even.
      Ask FixBot
    7. How To Sew With An Awl: step 7, image 1 of 3 How To Sew With An Awl: step 7, image 2 of 3 How To Sew With An Awl: step 7, image 3 of 3
      • Pull the thread from the eye of the needle, creating a loop.
      • Put the short, free end of the thread through the loop you just created in the thread.
      Ask FixBot
    8. How To Sew With An Awl: step 8, image 1 of 2 How To Sew With An Awl: step 8, image 2 of 2
      • Holding the short, free end of the thread taught, pull the awl back out through the material.
      • Pull both ends of the thread taught.
      Ask FixBot
    9. How To Sew With An Awl: step 9, image 1 of 3 How To Sew With An Awl: step 9, image 2 of 3 How To Sew With An Awl: step 9, image 3 of 3
      • Continue reinserting the awl, creating a loop of thread from the eye of the needle, threading the short, free end, and removing the awl to create your stitches.
      • While you are getting the hang of it, refer back to steps 6-9 of this guide.
      Ask FixBot
    10. How To Sew With An Awl: step 10, image 1 of 3 How To Sew With An Awl: step 10, image 2 of 3 How To Sew With An Awl: step 10, image 3 of 3
      • When you come to the end of your material, take one last stitch.
      • Clip the end of the thread that runs through the needle, leaving enough length to tie a couple of knots.
      • Remove the awl.
      Ask FixBot
    11. How To Sew With An Awl: step 11, image 1 of 2 How To Sew With An Awl: step 11, image 2 of 2
      • Tie an overhand knot with the two ends of the thread.
      • Pull taught.
      • Tie another knot or two to secure the stitching.
      Ask FixBot
    12. How To Sew With An Awl: step 12, image 1 of 2 How To Sew With An Awl: step 12, image 2 of 2
      • Clip the threads, and admire your handiwork.
      Ask FixBot
Finish Line
12 other people completed this guide.
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 74
Past 30 Days: 332
All Time: 22,788
