Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓Use this guide to safely disassemble, clean, and reassemble your hair dryer to address strange noises or odors. Maintaining it in this way extends its lifespan and supports a more sustainable, circular approach to appliances. Always confirm that servicing your device does not void any warranties.
Tools
Step 2 Remove any detachable parts
Take off any filters or covers that come away without using any tools.
Step 3 Undo the housing screws
Locate and remove the four screws on the handle or housing with a screwdriver.
Step 6 Access the motor and heating element
Lift the motor assembly gently, noting that it is attached to the heating element.
Step 7 Inspect for damage or burning smell
Examine wires and coils for discoloration, burns, or loose connections.
Step 8 Clean the interior
Use a vacuum or brush to remove hair, dust, and other debris from the motor and grill.
Remove lodged particles gently using tweezers if required.
Step 10 Reassemble all parts
Return the motor and heating element to their original positions with wires secured.
Align and snap the housing panels back together carefully.
Insert and tighten all screws that were removed earlier.
Step 11 Perform a test run
Plug in the hair dryer briefly to check for proper airflow and any odd noises.
Maintaining your hair dryer regularly keeps it efficient and safe while diverting waste from disposal. Servicing the device could affect any existing warranties, so verify your coverage first. If you are ever uncertain or find major damage, consult a certified technician for further assistance.
