How To Replace The Inlet Valve In Your Washing Machine
Views: 2.3K
View statistics:
Past 24 Hours:
19
Past 7 Days:
88
Past 30 Days:
357
All Time:
2,266
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows you how to replace the water inlet valve in your washing machine when it no longer starts, fails to fill, or continuously leaks water. Replacing this valve can restore normal water flow and fix issues with filling or flooding. Always check your manufacturer’s guidelines and be aware that any unauthorized repair could affect your warranty.
Parts
Tools
      • Unplug the washing machine from the electrical outlet to avoid electric shock.
      • Turn off the water supply to the washer to prevent flooding.
      Ask FixBot
      • Locate and remove the retaining screws or clips securing the top panel of the machine.
      • Lift or slide the top panel to expose the inlet valve assembly at the back.
      Ask FixBot
      • Loosen and remove any screws or brackets holding the inlet valve in place.
      • Label or photograph the wire connections to ensure correct reassembly.
      • Slide off any wire connectors from the old valve.
      Ask FixBot
      • Place a container or cloth beneath the internal hoses to catch spilling water.
      • Loosen and remove the hose clamps or clips from the valve’s outlet ports.
      • Slide each hose off the old inlet valve, being cautious of any water inside.
      Ask FixBot
      • Identify and note the ports for pre-wash, main wash, and softener if your valve has multiple outlets.
      • Confirm the softener port has the correct internal nozzle or insert as required.
      Ask FixBot
      • Attach each hose to the corresponding port on the replacement valve and secure the hose clamps.
      • Reinstall the valve in its original position and secure it with screws or brackets.
      • Reconnect the wire connectors in the same order you noted before.
      Ask FixBot
      • Restore power and water, but do not fully reattach the top panel yet.
      • Select a short wash or pre-wash cycle to check for correct water flow and leaks.
      • Turn the dial to the main wash and softener programs to verify proper flow in each compartment.
      Ask FixBot
      • Shut off the power once more and reinstall the machine’s top panel securely.
      • Observe any signs of water leakage before turning off the machine again.
      • Plug in your washer, turn on the water supply, and run a full wash cycle to confirm normal operation.
      Ask FixBot
Replacing the inlet valve restores proper water flow to your washing machine and can resolve filling or leaking problems. Remember to follow all safety guidelines, and consult the manufacturer’s instructions to ensure compliance with any warranty conditions. If uncertain, contact a qualified service technician.
Ula Gantar
16,636 Reputation
81 Guides authored
ZEOS Slovenia Member of ZEOS Slovenia
Local Repair Groups
2 Members
972 Guides authored
0 Guide Comments
Past 24 Hours: 19
Past 7 Days: 88
Past 30 Days: 357
All Time: 2,266
