Community-Contributed Guide
Introduction
Go to step 1 ↓A faulty door lock can prevent your washing machine from starting or keep the door permanently locked. Replacing the lock can restore normal operation. Before starting, unplug the machine and verify how this repair may affect your warranty. This guide is for informational purposes, and professional assistance is recommended if you are unsure.
Step 2 Identify a failing lock
Look for signs like unresponsive start commands or error codes indicating a lock problem.
Confirm that the door fails to lock when a cycle is selected or that indicator lights blink.
Step 3 Release the door if locked
Remove the top panel if the door is locked and water remains in the drum.
Drain excess water through the filter if the water level is above the door glass.
Use a tool from inside the top opening to release the latch if the door will not unlock.
Step 4 Expose the door lock
Locate and remove the metal clamp or spring holding the front door seal in place.
Pull the door seal away from the lock area using a flat screwdriver.
Step 5 Remove the old assembly
Lift the rubber seal to uncover the screws.
Unscrew the fasteners securing the lock assembly while supporting it from behind.
Carefully disconnect the wires or connector, noting how each cable is attached (take a picture).
Step 6 Fit the new lock
Align and secure the new lock assembly, ensuring proper orientation of connectors.
Tighten the screws carefully to form new threads in the fresh lock assembly.
Reposition the door seal in the groove and reattach the clamp firmly.
Step 7 Reassemble and test
Check that the door seal is sitting correctly and all screws are snug.
Plug the machine in and run a short cycle to verify the new lock engages properly.
Replacing the door lock can restore proper functioning to your washing machine. Always review warranty terms before any repair, and if you are unsure of any steps, contact a professional. This guide is intended for informational purposes and may not suit every model.
