How To Replace Ski Pole Baskets
    1. How To Replace Ski Pole Baskets, How To Replace Ski Pole Baskets: step 1, image 1 of 2 How To Replace Ski Pole Baskets, How To Replace Ski Pole Baskets: step 1, image 2 of 2
      • Place the sock over your hand like a glove.
      • You will be using this hand to pull off the heated basket.
      Ask FixBot
    2. How To Replace Ski Pole Baskets: step 2, image 1 of 2 How To Replace Ski Pole Baskets: step 2, image 2 of 2
      • Heat the worn/broken basket with a blow dryer to melt the existing adhesive.
      • Heat for no longer then three minutes.
      Ask FixBot
    3. How To Replace Ski Pole Baskets: step 3, image 1 of 2 How To Replace Ski Pole Baskets: step 3, image 2 of 2
      • Use your protected hand to pull firmly on the basket until it comes off of the pole once it is heated.
      Ask FixBot
    4. How To Replace Ski Pole Baskets: step 4, image 1 of 2 How To Replace Ski Pole Baskets: step 4, image 2 of 2
      • Heat an all purpose glue stick with a lighter.
      Ask FixBot
    5. How To Replace Ski Pole Baskets: step 5, image 1 of 2 How To Replace Ski Pole Baskets: step 5, image 2 of 2
      • Spread a very thin layer of the melted glue on the basket end of the pole, then press on the new basket.
      • Press the new basket immediately after applying the melted glue in order to obtain maximum adhesion.
      Ask FixBot
    6. How To Replace Ski Pole Baskets: step 6, image 1 of 1
      • Reheat the replaced basket with a hair dryer for a minute.
      • After heating, allow the glue to cool and set for 10 minutes.
      Ask FixBot
    7. How To Replace Ski Pole Baskets: step 7, image 1 of 1
      • After drying for 10 minutes, your poles will be ready for use. Happy Skiing!
      Ask FixBot
2 other people completed this guide.
Lia Garkie
158 Reputation
1 Guide authored
Cal Poly, Team 30-3, Green Spring 2015 Member of Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Members
71 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 49
All Time: 18,844
