Up to 20% off select tools
How To Repair A Paintbrush Handle
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
104
All Time:
653
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
There's no need to throw away the whole brush if the handle has cracked, come loose, or just seen better days. A quick, cheap handle repair can make a brush you already trust last longer. Most of the time, damage happens because the tool is used a lot, gets wet, or is thrown around in a toolbox. But with a little patience and the right materials, you can fix it.
Before you begin, make sure you have some basic tools on hand: wood glue or epoxy, sandpaper, and maybe wood filler if the handle has deeper cracks. Also, get some oil or varnish if you want to refinish it. If you're using stronger adhesives or finishes, make sure the area is well-ventilated. If you don't want glue on your hands or splinters, wear gloves.
This guide shows you how to get your brush back in working order so you can use it for your next project.
    1. How To Repair A Paintbrush Handle, How To Repair A Paintbrush Handle: step 1, image 1 of 1
      • Clean the broken ends of the paint brush using a cotton swab and a small amount of rubbing alcohol to remove dirt, paint flakes, and oils.
      • This allows the glue to bond better.
      Ask FixBot
    2. How To Repair A Paintbrush Handle: step 2, image 1 of 1
      • Apply super glue to one of the broken ends.
      • Apply it evenly and avoid using too much, since the excess may spread out.
      Ask FixBot
    3. How To Repair A Paintbrush Handle: step 3, image 1 of 1
      • Join the pieces together. Make sure the tip and the brush are aligned as straight as possible to best use.
      Ask FixBot
    4. How To Repair A Paintbrush Handle: step 4, image 1 of 3 How To Repair A Paintbrush Handle: step 4, image 2 of 3 How To Repair A Paintbrush Handle: step 4, image 3 of 3
      • Use a zip tie or anything that can keep the pieces tightly together while the glue dries.
      Ask FixBot
    5. How To Repair A Paintbrush Handle: step 5, image 1 of 1
      • Remove any excess glue with a cotton swab or damp cloth before it hardens.
      Ask FixBot
Finish Line
Author
with
Alex Luna
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 104
All Time: 653
