How To Properly Use And Maintain Your Juicer
    • Examine whether you use a traditional centrifugal juicer or a slow auger juicer to understand performance and noise levels.
    • Recognize that smaller centrifugal models have a narrow feed chute and might require more chopping.
    • Notice that larger centrifugal models have a bigger feed chute, letting you use larger produce pieces.
    • Slow or auger juicers compress produce at lower speeds and can handle leafy greens more effectively.
    Ask FixBot
    • Unplug the juicer from the power source before handling the internal parts or performing any maintenance.
    • Clean and cut fresh produce to fit into the feed chute, especially for smaller centrifugal machines.
    • Apply gentle pressure when inserting hard ingredients such as beetroot to avoid straining the motor.
    Ask FixBot
    • Plug in the machine only when ready to juice and ensure the lid is securely attached.
    • For slow juicers, use the reverse function if ingredients become jammed to release stuck pieces.
    Ask FixBot
    • Place a small bag inside the pulp container to make cleanup easier and allow reuse of pulp if desired.
    Ask FixBot
    • Use the slow juicer to puree tomatoes or softer fruits, collecting juice and pulp separately.
    Ask FixBot
    • Clean the juicer parts immediately after use to prevent build-up and reduce scrubbing time.
    • Discard or reuse all pulp, taking care to empty the container before washing.
    • Avoid using a dishwasher for the filter or mesh to prevent damage or warping.
    • Use a soft brush under running water to remove residue from both the fine mesh and removable parts.
    • Apply the same cleaning rules for slow juicers, including rinsing the auger and strainer right away.
    Ask FixBot
    • Check the device manual to avoid any action that could void your warranty or risk damage.
    • Store all parts in a dry place and handle them carefully to prolong the motor and component lifespan.
    Ask FixBot
A juicer can deliver fresh, nutritious beverages if met with proper use and care. Clean right after juicing and respect the device’s specific guidelines for a smooth experience and longer service life. Always remember to unplug your juicer before any maintenance to stay safe and maintain your warranty.
Ula Gantar
16,609 Reputation
81 Guides authored
ZEOS Slovenia Member of ZEOS Slovenia
Local Repair Groups
2 Members
95 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 33
All Time: 210
