Up to 20% off select tools
How To Install Universal Fit LED Daytime Running Lights
Views: 98K
View statistics:
Past 24 Hours:
5
Past 7 Days:
54
Past 30 Days:
232
All Time:
97,517
Comments: 11
11 guide comments.
Go to guide comments
Completed: 21
21 people have marked this guide "completed." Will you be next?
Favorites: 22
22 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
LED daytime running lights are a great add-on to any vehicle to increase light output for style and safety. Some LED daytime lamps are vehicle specific, but this set of Philips Style LED DRL is universal fit for more cars and SUVs.
    1. How To Install Universal Fit LED Daytime Running Lights, Philips Style LED Daytime Running Lights Upgrade: step 1, image 1 of 1
      • Insert the wire into the bracket.
      Ask FixBot
    2. How To Install Universal Fit LED Daytime Running Lights: step 2, image 1 of 1
      • Mount the bracket. Since this is universal fit, you can mount it anywhere you'd like.
      Ask FixBot
    3. How To Install Universal Fit LED Daytime Running Lights: step 3, image 1 of 1
      • After mounting the bracket, you can lock the LED daytime running light on the bracket.
      Ask FixBot
    4. How To Install Universal Fit LED Daytime Running Lights: step 4, image 1 of 2 How To Install Universal Fit LED Daytime Running Lights: step 4, image 2 of 2
      • Connect the wires and route the wires up and near the fuse box.
      • Use zip ties to tie the wire along the bumper.
      Ask FixBot
    5. How To Install Universal Fit LED Daytime Running Lights: step 5, image 1 of 2 How To Install Universal Fit LED Daytime Running Lights: step 5, image 2 of 2
      • Find the ACC in your fuse box and tap the red wire there.
      • You can find the ACC location using an electronic meter by clamping the black wire to the battery negative or ground.
      • When you find ACC, tap the red wires to the blade of the fuse and insert it back.
      Ask FixBot
    6. How To Install Universal Fit LED Daytime Running Lights: step 6, image 1 of 1
      • Tap the black wire to battery negative.
      Ask FixBot
    7. How To Install Universal Fit LED Daytime Running Lights: step 7, image 1 of 3 How To Install Universal Fit LED Daytime Running Lights: step 7, image 2 of 3 How To Install Universal Fit LED Daytime Running Lights: step 7, image 3 of 3
      • Test to make sure everything works and enjoy your new universal fit Philips Style LED Daytime Running Lights.
      Ask FixBot
As you can see, installation isn't complicated and if you follow the directions accordingly, you'll be on your way to new LED daytime running lights in no time.
21 other people completed this guide.
Author
with
Eric Wu
3,600 Reputation
23 Guides authored
11 Guide Comments
Useful information shared. Thanks for giving us nice info. Fantastic walk through. I appreciate this post and here is my link
http://optixautolabs.com/
Calvin Macaraeg - Reply Share
Useful info. Thanks
grant.edson - Reply Share
great information and pictures, just one thing, what size of fuse should I use for connection in fuse box.
steve finlayson - Reply Share
UK road/MOT law states you must 60% dim or better still, make DRL’s turn off when headlights are turned on … stop advertising fake information Phillips and start stating some facts for a change
i cry when i wii - Reply Share
Past 24 Hours: 5
Past 7 Days: 54
Past 30 Days: 232
All Time: 97,517
