Up to 20% off select tools
How To Fix a Sharp LC-55Q7530U LED Backlight Issue
Views: 4K
View statistics:
Past 24 Hours:
11
Past 7 Days:
61
Past 30 Days:
301
All Time:
4,047
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Parts
Tools
Introduction
Go to step 1 ↓
Welcome to my comprehensive guide on troubleshooting and repairing backlight LED issues in your SHARP LC-55Q7530U TV. This guide helps you fix the common issue of a black TV screen or a TV screen rapidly turning on and off. By following clear, step-by-step instructions, you'll learn to diagnose backlight problems, disassemble your TV, identify faulty components, and perform replacements.
This guide has a moderate difficulty level, making it accessible to individuals with basic electronics knowledge.
    1. How To Fix a Sharp LC-55Q7530U LED Backlight Issue, LED Backlight: step 1, image 1 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue, LED Backlight: step 1, image 2 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue, LED Backlight: step 1, image 3 of 3
      • If the TV screen is completely dark, or it turns on and turns back off instantly, there is likely a backlight problem.
      • If there is a backlight problem, fixing it will require you to remove the back of the TV
      Ask FixBot
    2. How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 2, image 1 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 2, image 2 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 2, image 3 of 3
      • Remove the screws from the back panel. Carefully open the back panel, then gently pry open the housing, being careful not to damage internal components.
      Ask FixBot
    3. How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 3, image 1 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 3, image 2 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 3, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the screws and gently pry off the cover using your fingers.
      • If the cover doesn't come off easily, wiggle it gently until it loosens and can be removed.
      • Carefully unplug the wires from their connectors.
      • Some connectors may have a latch that needs to be pressed before pulling them apart. Be gentle to avoid breaking the connectors.
      • With all screws and wires detached, lift the speaker unit gently out of its spot, holding it from the sides or bottom to prevent any damage.
      Ask FixBot
    4. How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 4, image 1 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 4, image 2 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 4, image 3 of 3
      • To disassemble the on/off button, remove the surrounding panel or cover, then unscrew any screws holding the button in place. Carefully disconnect any wires or connectors; this will allow you to separate the button from the device.
      • To remove the LCD screen, attach suction cups to opposite ends, apply even pressure, and gently lift the screen from the device. Ensure careful handling to avoid damage.
      Ask FixBot
    5. How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 5, image 1 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 5, image 2 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 5, image 3 of 3
      • Wipe the LCD screen clean with the microfiber cloth to ensure a good grip. Firmly press a suction cup onto the center of the screen, eliminating air bubbles to create a seal. Apply gentle, even pressure to lift the screen slightly.
      • If resistance is encountered, gently wiggle the suction cup to create a gap. Carefully move the suction cup or use your fingers to widen the gap, maintaining gentle, even pressure. Continue lifting the screen, moving the suction cup around the edges, until it is completely detached.
      • Avoid straining cables or internal components during the process. Place the removed LCD screen in a secure, soft location to prevent scratches or damage.
      Ask FixBot
    6. How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 6, image 1 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 6, image 2 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 6, image 3 of 3
      • Look for burnt-out LEDs, which might appear dark or black. If you find faulty LEDs, they need to be replaced.
      • Use a multimeter or backlight tester to test the voltage output of the LED driver board. If the voltage is incorrect, the LED driver board might be faulty and needs replacement.
      Ask FixBot
    7. How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 7, image 1 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 7, image 2 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 7, image 3 of 3
      • None
      Ask FixBot
    8. How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 8, image 1 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 8, image 2 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 8, image 3 of 3
      • If individual LEDs are the issue, you can replace them by using soldering kits and a compatible replacement LED strip. Make sure to get a model compatible with your TV.
      Ask FixBot
    9. How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 9, image 1 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 9, image 2 of 3 How To Fix a Sharp LC-55Q7530U LED Backlight Issue: step 9, image 3 of 3
      • Carefully reassemble after replacing the faulty components, making sure all connections are secure.
      • Plug in the TV and turn it on to see if the backlight issue is resolved. Monitor the TV for some time to ensure the problem doesn’t recur.
      Ask FixBot
Repairing your TV's backlight LED issues is entirely achievable with the right guidance and tools. In this process, we've covered essential steps from diagnosing the problem to safely disassembling the TV and identifying faulty components. By using a systematic approach and being meticulous in handling both the hardware and electronic components, you can successfully address backlight problems.
Author
with
Khalid Riad
190 Reputation
1 Guide authored
1 Guide Comment
I have this same TV model LC-55Q7530U which went out a week ago. The TV suddenly has no video or sound; the sharp logo can be seen faintly when turned off and on. I have serviced TCL tv's that had the same issue only showing the faint logo seen when shinning a flashlight on the screen. This was usually a fix starting with replacing the mainboard and solved the issue. My question to anyone that may have performed the backlight replacement did it solve the issue; also did you see the sharp logo prior the service? I am just tinkering with this TV before possible discarding it since a replacement has already been purchased. I don't mind opening and checking the backlights but also don't want to chance losing money on purchasing other parts.
Orlando Sanders - Reply Share
Past 24 Hours: 11
Past 7 Days: 61
Past 30 Days: 301
All Time: 4,047
